Old 06-02-2010, 11:38 AM
mzavaro mzavaro is offline
Default will lt1 t56 fit on a ls3 2010 camaro ss motor?
Hey guys, quick question!
Got a 69 camaro. Purchased an ls3 motor out of a 2010 camaro ss, NOT corvette. I was told by the Chevrolet dealer that an Lt1 T56 is what's needed to bolt up to that motor but then also heard that Lt1's don't bolt up to LS engines. Which is true? Thank you guys, appreciate your help!
Old 06-02-2010, 12:31 PM
awr68's Avatar
awr68 awr68 is offline
You need a LSx T56.
Tony
'68 Camaro
Old 06-02-2010, 12:37 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
The Chevy dealer is wrong, you could want an LS1 T56.
Old 07-11-2010, 07:23 AM
xx_ED_xx xx_ED_xx is offline
Yes if you swap out input shaft and front plate of trans where the input goes. Unless you have the 1993 bastard t56
