Old 06-05-2010, 01:14 PM
J-440's Avatar
J-440 J-440 is offline
Greg, so just wire the relay using Meziere's harness between the pump and the fusebox/ignition switch? Would I still need to use the relay even though I'm using a 140 amp alternator as well as the stock voltage regulator? Thanks again.
68 Charger, 440SC, EFI, 6-speed
