Old 06-09-2010, 05:55 PM
g356gear's Avatar
g356gear g356gear is offline
Default Which MSD Ignition, Distributor, Coil??
Hey guys,
The MSD site is a little overwhelming with all the distributors, coils, and ignitions available. I need to switch out the stock distributor and ignition set up for something a little better and that I can run a tach and possibly the EZ EFI system that needs to have a tach signal for reference. Application is a Big block chevy so firewall space is a little limited. Nothing too radical, 600hp, street driver. Thanks for the input.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 06-13-2010, 11:35 PM
my favorite set up to run was the MSD 6-AL (MSD 6420) control box with a Pro-billet distributor (MSD 8361) with compact cap and a Blaster 2 coil (MSD 8203). Cheap and easy.
vince
Old 06-14-2010, 09:04 AM
g356gear's Avatar
Thanks!
Old 06-15-2010, 08:12 PM
Taman Taman is offline
I run the Blaster 2 coil that is for high vibration and a billet msd distributor. 12 years of trouble free operation.
