Old 07-07-2010, 02:09 PM
Default Key less Push Button start is here!
We have been waiting for this for a long time and finally it is finished by one of my favorite companies. IDidIt now has Key less Push Button start for both key less and keyed columns.
We have the very first production unit being installed in Project Unfair. We have them in stock and they are only $399!
These work with key less columns, you can put the button anywhere you want. The console and dash will be the most likely locations
Or if you have a keyed IDidIt column, we will modify your column and will insert the push button in the key location on your column for $75.
Want your key column key to disappear and be a smooth key less column and remote button, it is $75 labor + $50 to $75 for a new key less collar depending on the finish of your column
So anyway you want it, we got ya covered.
Click on any of the below links for more information
Frank Serafine
Old 07-09-2010, 09:47 AM
Payton King's Avatar
Default How does it work for an "on" position
I normally turn my car on and let the electic fuel pump build pressure before I crank it....can/will it do that?
Old 07-09-2010, 11:59 AM
rjsjea's Avatar
rjsjea rjsjea is offline
Good question.
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 07-09-2010, 03:17 PM
130fe 130fe is offline
Thumbs up
Would be cool to have it function like the OEM ones (like in my toyota) that allow you to have ignition power with one press and start on the second push (with parking brake pedal pushed). Frank, how would it be functional in a manual trans application?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-09-2010, 04:30 PM
I think by mid week I will be able to field all questions.
Frank Serafine
Old 07-09-2010, 07:20 PM
DRJDVM's '69's Avatar
Most of the pushbutton starts are one push....accessories on, like the the fuel pump.....then hold it down and the car cranks
