Old 08-04-2010, 11:07 AM
Lateral-g Moderator
Just turn the radio up or get a bigger sub.
Old 08-04-2010, 01:14 PM
Blake Foster's Avatar
what he said ^ lol
thats the first thing i always tell customers, JK
Blake Foster
www.speedtechperformance.com
Old 08-04-2010, 03:22 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
If you can hear it by bouncing the car sittin still then if you can get underneath it or have it on a drive on lift you should be able to "feel" it with your bare hand on the joint or the arm that is making the noise. In other words, what you feel in your hand is in sync perfectly with what you hear.
I chase these noises regularly on new "regular" cars and this method really works well believe it or not.
g356gear's Avatar
g356gear g356gear is offline
I dont know if the stock am radio and dash speaker are gonna cut it.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 08-12-2010, 10:36 PM
What's the verdict? I'm right of course.
Old 08-13-2010, 09:17 AM
of course lol
Blake Foster
Old 08-13-2010, 09:36 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Goes without saying.
Doug
Old 08-13-2010, 11:58 PM
Thanks guys...
Old 08-16-2010, 08:06 AM
g356gear's Avatar
Its been raining and crappy for the last week and a bit. Hoping to have the car out in the next couple of days to check and see if the magic silicone spray works. I loosened off all the heim joints with the suspension relaxed, compressed it back up to ride height, aligned all the joints and tightened it all up again. I also regreased the sway bar, upper and lower control arms again while the car was in the air. We will see what happens.
Old 08-16-2010, 01:16 PM
g356gear's Avatar
Got a break in the weather and took the car over to the body shop for an evaluation this morning. Squeak is still there, but not as bad. I think I will hit the joints a few more times and see if it helps.
