Old 06-09-2010, 09:52 PM
aany001's Avatar
aany001 aany001 is offline
Default What to paint my floors with?????
I wonder what everyone is doing with all new floors front to back and it has the EDP coating......what should I paint them with for the best sound proofing and protection.This will be a driver so show worthy is not the case here.Any insight would be appreciated.
Steve
Old 06-10-2010, 03:50 AM
GPR's Avatar
GPR GPR is offline
I would spray it with SPI epoxy primer and you can also use their spray in bed liner. www.southernpolyurethanes.com
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 06-16-2010, 07:58 PM
aany001's Avatar
not painting the shop floors..............floors in my car
Old 06-16-2010, 11:51 PM
bed liner lizard skin....make sure you check the out gassing potential of what ever you use. my buddies camaro smells like a meth lab when its hot out.
Old 08-31-2010, 07:12 PM
av8or32 av8or32 is offline
Got some epoxy primer from NAPA and used a cheap gun with GREAT results! It's the way to go IMO. A lot of the pros recommend epoxy
Old 09-02-2010, 09:04 PM
HerbyJr HerbyJr is offline
My floor was rusty, but not rusted through. Since I didn't want to replace the floor pans, and they were still structurally solid, I painted them with POR-15 which encapsulates the rust and stops it from spreading. I know your floors are new, but if you can find something like a POR-15 that might make the floors more rust resistant, you'd be ahead of the game. Good luck.
H.
Old 09-16-2010, 10:26 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
The Eastwood company sells their version of POR15- called rust encapsulator. It's good stuff.
http://www.eastwood.com/rust-encapsulator.html
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 09-23-2010, 05:31 AM
Jay Hilliard's Avatar
I will use PPG DP epoxy primer, seam seal and then use Raptor spray on bedliner.
Jay
