Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 09-12-2010, 10:29 PM
ccreddell's Avatar
ccreddell ccreddell is offline
If Im not mistaken, rebuilding a 350 would be less expensive than rebuilding a 305-if being built the same. Parts for a 350 usually are cheaper than just about anything else. And the pistons would be the only difference anyway, and thats if the pistons need replacing in the first place.
Old 09-13-2010, 08:22 AM
street3285 street3285 is offline
Travis
Old 09-13-2010, 09:24 AM
N2TRUX's Avatar
N2TRUX N2TRUX is offline
Oh, that makes more sense. Nothing wrong with a 305 besides lack of cubic inches...
Old 09-15-2010, 02:36 PM
deuce_454's Avatar
and the shrouding of the valves.. will the valves in the vortech heads even clear the bores???
Jake: Hit it.
Old 09-15-2010, 03:37 PM
Travis
Old 09-17-2010, 09:39 PM
ccreddell's Avatar
If Im not mistaken, they made 305 Vortec heads-in fact, I would think youd have to be careful not to put them on a 350. But Ive been wrong before.......
Old 09-23-2010, 07:19 AM
Travis
Old 10-24-2010, 04:48 PM
Travis
Old 10-31-2010, 07:25 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Originally Posted by ccreddell View Post
If you get a hold of a Dropmember, you'll have no clearance issues and you can go as low as you want. You get R&P steering too. Theres even an option to use the complete front suspension out of a C4 Corvette. Im shopping around for a clean Square Body to get started on...........
I've got a 84 square body that I've had for awhile, I just bought that front end from Nate at Porterbuilt can't wait to get started on it. It's like getting the complete DSE setup for a Camaro. I plan on bagging it and laying it on the ground .
TRACY WEAVER
www.recoveryroominteriors.com
Old 10-31-2010, 11:42 PM
ccreddell's Avatar
From what I recall, the C5 DM doesnt lay frame-close, but not quite. It just handles real well. Be sure and make a build thread, and link to it from here.
