Old 09-21-2010, 07:03 AM
coolwelder62's Avatar
Thank's Jody,It's been great working w/ Jody and everybody else here on Lateral -G. I just want to build quality suspension pcs. that work good at an afordable prices.
Old 09-22-2010, 05:55 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
Yeah, Scott's work is awesome and I would definitely get another one from him. The fit up and welds look great. Scott is a great guy and very easy to work with. He's pricing is great with great quality work.
On my Javelin, the plan at first was to splice it into the original frame rails. But after taking some time looking at the original frame and a little luck, it was easier and better in my application to remove the existing frame and build a new front sub.
Thanks,
Jon
Old 09-22-2010, 06:12 PM
Jon how you fabbed up the frame for your javelin is cool I might have buy the drawings from you if find me a humpster.
Old 09-22-2010, 08:13 PM
millerman340's Avatar
millerman340 millerman340 is offline
I'm still not considering cutting the rails just yet. That cross-member is 2x4 .190 & the LCA cross bars that I have are cold rolled 1.25 solid bar ( Trust me, I have have access to digital measuring tools to locate the the LCA shafts & the smarts enough to make it straight & true . I believe welding it in plus strategic location from Scott & using with his steering arms & sway bar setup I can keep my rails.
Old 09-28-2010, 03:07 PM
Seeing that I'm dead at work I continued with the lower mount with some help from one of our members, I decided to go with a 60.5 track.
Old 10-18-2010, 01:16 PM
Old 10-18-2010, 06:02 PM
nvr2fst nvr2fst is offline
Salviggio Auto Design (formally perfection autoworks) has done an AME C6 clip in a Charger and Challenger recently. Slight modification was needed. You may find something on his website showing the install, not sure.
Sooner or later somebody has to hit that market more than whats offered now.
Old 10-18-2010, 07:01 PM
Nice cars on their site! I don't think the tops of the Mopar frame rails are strong enough for the upper mounts. Looks like I'll have to section them & make a stronger rail in that area but keep the stock dimensions to make it unnoticeable. So much for not chopping!
Old 10-31-2010, 09:19 AM
Old 11-14-2010, 06:10 AM
R.A.D's Avatar
R.A.D R.A.D is offline
the key word is c5, or c6 thats where the stigma comes in. but aftermarket parts are aftermarket parts. unless everything has a gm part number on it. i am a mopar guy aswell, i used to do "the get there in a straight line as fast as you can thing" but to let the nomenclature used on a part keep you from building the car you want, i don't understand... it would be the same with a mustang rack and pinion, a toyota turbo, how many after market steering columns are gm style. but that dosen't stop them from being used. the key word i think is style. c5 style, c6 style ect.. they are just chassis parts,
i had a friend who ran smallblock fords he would install chevy vales in his ford heads. but are they chevy valves or just valves?
just my $.02
