Old 10-06-2010, 09:08 AM
Steve1968LS2's Avatar
If you can't find them and HAVE to have them then there are companies that will make bolts to order.
http://www.zerofast.com/service.htm
For instance, nobody made the 12mm x 80 x 1.5 that I needed. These guys had them to me in two days.
But be prepared for sticker shock.. limited runs of anything is expensive. Still, it's nice to have options.
Old 10-06-2010, 09:11 AM
ccracin's Avatar
ccracin ccracin is offline
I deal with metric fasteners every day and checked our suppliers. Those sizes do not seem to be "standard" for that style of bolt. You may have to go the custom route if you are dead set on those. it looked as thought you could get the socket head screws in those specifications. Good luck.
Chad
Instagram - @cctek
68 Chevy Pickup Project
