Closed Thread
Old 09-21-2008, 05:42 PM
Birdman's Avatar
Birdman Birdman is offline
Default Bunch of LS1 parts for sale!
Stock LS1 rocker arms. Unsure of mileage, but they were lower when they came off. They came from a friend's 00 SS. $50
Stock 99+ LS1 cam. Great shape, yanked with low mileage - $40
LS2 timing chain, good shape - $20
Ported LS6 oil pump. I want to say it came from Futral, but don't hold me to that! In great shape, been on the shelf a while - $100
Stock LS1 valve springs - $20
1998 Trans Am - BMR drop springs, BMR LCA relos, Bilstein shocks, Sportmax 18x9.5 wheels, lots of goodies, 6-spd swap, lQ9 swap
1968 Camaro (Patriot Dream project) - Iron LS1, T56, lowered and nitroused PT machine
PatriotDream.org - Help make a soldier's dream come true
Old 09-21-2008, 05:44 PM
Birdman's Avatar
Stock T56 shifter handle - $5
Hurst shifter rod with 1 Ball epoxied on - $5
Stock Hurst shifter for T56 with rod and knob - $60
Stock factory shifter - $20
Stock LS1 starter, good shape - $50
Old 09-21-2008, 05:45 PM
Birdman's Avatar
Stock T56 slave cylinder, great shape - $30
5.3L/4.8L block, completely bare, but in good shape. I was using it for mockup. $50, pickup only
5.3L shortblock, block/crank/pistons/valley pan only, good shape with 30k miles on it. $250
Bare 706 5.3L heads, great shape, can include the 5.3L valves and springs if you want (they were stripped after the pic was taken, also cleaned up in a vat). $100
Two front 91 Z28 wheels, good shape just need cleaning. $75
Birdman's Avatar
87 TPI setup - Complete down to the 9th injector, includes TB, but no distributor cover. - $175
NO PICTURE
Barnes 6-stage dry sump oil pump - good shape, needs new pulley most likely. $200
Stock alternator. Dirty, but works great - $50
LS1 injectors. Good shape, with clips - $65
LS1 front plate, great shape - $30
LS1 water pump, good shape - $40
Old 10-23-2010, 08:20 PM
ss9t7camaro ss9t7camaro is offline
Default shifter
do you still have the shifters if so do you have a way i can contact you
Old 10-24-2010, 07:03 AM
1969x11's Avatar
1969x11 1969x11 is offline
Pm sent..
Old 10-24-2010, 05:03 PM
Z06vette's Avatar
Z06vette Z06vette is offline
This is over 2 years old.... in case you didnt catch it.
Old 10-24-2010, 05:47 PM
1969x11's Avatar
Rat's ass, no I didnt. Thanks for the heads-up.
Old 10-24-2010, 05:53 PM
These revivals are funny, but ya never know if people still may have the things for sale. I have found a couple things from very old For-Sale posts on this forum that I needed and were still available!
Closed Thread
