Old 10-20-2010, 03:29 AM
jake72ss jake72ss is offline
what would be wrong with building the end of the torque arm like Griggs does
http://www.howardweb.org/fastgt/docs/griggs_arm2.jpg http://www.griggsracing.com/images/MTA1000RST.jpg
it looks like the hole in the crossmember is a bit larger than the sleeve and that allows the torque arm to slide front to rear and side to side.
Would this have any downsides?
Old 10-20-2010, 12:39 PM
exwestracer's Avatar
exwestracer exwestracer is offline
If you're planning on limited travel and body roll, nothing wrong with it at all. The bushings even give you the opportunity to "tune" how the arm hits the chassis slightly. Just be careful when jacking the car up, etc. not to over articulate the bushings.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 10-20-2010, 01:56 PM
Read up on this for a bit.
http://www.unbalancedengineering.com/Camaro/TA/
Tyler
Old 10-20-2010, 09:11 PM
funcars funcars is offline
I understand after seeing the picture - Thanks. If the link was oriented to be in tension during braking then I guess the same issue would surface during acceleration when the link would be in compression?
I've never been a fan of the implementation of the Griggs torque arms or watts links. They do seem very durable and functional on a race track where you don't care about noise or vibration - they just need to work and can't break.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 10-21-2010, 08:33 AM
BMR Tech's Avatar
BMR Tech BMR Tech is offline
Is your torque arm built from round tube or square? If square we have a machined slider insert with Delrin bushing and poly mount you could use. It fits into a 2x2 x.120 tube. This is what we use at the front of our torque arm kit. The slider tube slides on 6 inches of Delrin equipped with grease channels and a grease fitting. The whole setup is bind-free...
Brett
WWW.BMRSUSPENSION.COM
Old 10-21-2010, 12:55 PM
1Bad68Cat 1Bad68Cat is offline
Hello Brett,
Sent you a PM.
Robert
Old 10-22-2010, 11:13 AM
Yes. That's one argument for using the sliding front mount. IMO, the double spherical is a little more compliant over bumps, as the double mount has no true center of rotation. Probably splitting hairs...
Old 10-25-2010, 10:47 AM
pacificustoms's Avatar
pacificustoms pacificustoms is offline
What about using the slip joint from a driveline?
Robbie Azevedo
Pacific Coast Customs
Become a fan on facebook for weekly updates and giveaways: http://www.facebook.com/pacificcoastcustoms
Old 10-25-2010, 04:55 PM
Boy, now there's a really interesting idea... You could probably find a flange mount ujoint and bolt the flange to a plate on the crossmember and use the whole works, ujoint and all...
Old 10-27-2010, 06:04 AM
ProTouring442's Avatar
You'd have to find a way to accommodate the twisting motion as the slip joint from a drive-shaft will be grooved.
Shiny Side Up!
Bill
Never met a man with real talent who felt the need to deride the efforts of other.
