Old 11-10-2010, 10:14 PM
rascc1 rascc1 is offline
Default what rear setup to run?
So I have started my 69 Camaro project finding out it needed pretty much a back half installed. My DSE mini tubs are on the way. I have looked at several rear end set ups from DSE, TCI ,rear truck arms ,Heidts. I may be even more confused now than when I started. The plan for the car is a daily commute slash canyon runner that will never be raced but the leaf springs have to go! I like the the DSE setup but with dollars going out faster than coming in what are my options? Engine specs are 550 hp with a 4 speed and 10 bolt posi. I am using the stock sub frame with tubular control arms and C-5 brakes any input would be greatly appreciated thanks.
Johnhttps://lateral-g.net/forums/images/smilies/willy_nilly.gif
Old 11-10-2010, 10:46 PM
What's wrong with leaf springs?
Old 11-10-2010, 11:25 PM
Ride quality.
Old 11-11-2010, 08:45 AM
Smile
I am looking for ride hieght adjustabilty and also don`t want to modify my fuel tank. Other than that nothing!
Old 11-11-2010, 09:18 AM
Blake Foster's Avatar
The official i'm blowing my own horn reply
what about this option? speedtech torque arm. Ride is excellent, install is a breeze.
all the adjustability you could want
5th over all in the Optima Challenge with a 510hp ls2
Blake Foster
www.speedtechperformance.com
Old 11-12-2010, 12:40 AM
exwestracer's Avatar
exwestracer exwestracer is offline
X2 on the torque arm. Very simple install, and no real faults.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 11-12-2010, 01:14 AM
ls1wot ls1wot is offline
What's the difference between the bmr torque ARM and speedtech? Maybe some one can do a comparo.
Old 11-12-2010, 04:05 AM
The Speedtech is proven with a couple of suspension challenges to back it up!
No one has more suspension options or experience then we do. We have 5 rear suspension solutions NOT including leaf springs. 5 brands, 5 approaches, feel free to call and discuss
Frank Serafine
Old 11-12-2010, 09:16 AM
Can't comment on the BMR set up but ours. Ease of install, Room for exhaust 3" is not an issue. ride height (on our torque arm the first thing to even come close to contacting would be the drive shaft on the tunnel, but you wouldn't run that low anyway) Articulink trailing arms for NO bind.
and 5th place in the Optima challenge.
Blake Foster
Old 11-12-2010, 12:23 PM
dsster's Avatar
dsster dsster is offline
I vote for Speedtech torque arm suspension. installation is so easy everything fits like a champ with a wide variety of adjustments. the good thing about was i did it myself in my garage did not have any help from nobody except technical support from speedtech, Roger and Blake. Thanks guys.
also i manage to fit 345"x18" wheels on a 70 nova with a dse tubs (street use only auto cross i used 325" tires). I cut the frame a little more than i supposed to and then i stretch out the tubs since the shock/spring upper crossmember will stenghten the frame.
