Old 11-23-2010, 09:20 AM
v8s10kid's Avatar
v8s10kid v8s10kid is offline
changed plugs, better still doing it tho. hopefully the mechanic will let me stick around so i can learn some $#!%
1984 v8 s10 - teal, short wheelbase, 15 inch rally wheels, 305 h.o. , muncie m22, dual super 40's, much more (daily driver)
1998 ford escort - enduro race car, 2.0 sohc, auto, only driven to church on sunday
Old 11-29-2010, 06:12 AM
v8s10kid's Avatar
cant get it to the mechanic so i did some more checking. also adjusted the idle mixture screws a bit.
-20 inches of vacume at idle (was 18 before adjustment)
-the accelerator pump nozzle is spraying a pritty thick stream of fuel
-changed vacume secondarys from silver to long yellow spring (lighter)
still need to check the floats and borrow a timing light from someone to check the timing. but i have to go to work , hope its at least better now.
Old 12-02-2010, 10:17 AM
v8s10kid's Avatar
new msn cap and rotor, better but still there.
float levals are good, and as i said i got 19.5 inches of vacume on idle.
gona see if i can steal *ahem* i mean borrow someones timing light.
what do you guys think timing should be?
1983 305 H.O.
edelbrock performer intake
holley 570cfm street avenger
stock hei with:
-msd coil
-msd cap and rotor
msd wires
shorty headers
2.5 inch flowmaster exhaust
also, idk if this matters but the timing tab is straight above the balancer behind the water pump
Old 12-02-2010, 11:25 AM
Okay -- so tuning an engines timing is a function of MANY MANY things and a guy could write a book trying to explain all of that on a forum like this.
Timing is "what the motor wants" ----- and there's MANY things that affect what the motor wants.
Timing is not just @ idle.... it's timing at IDLE and the CURVE and TOTAL timing... and messing with the timing at idle will affect the TOTAL and vice versa....
Gasoline quality and the distributor CURVE and the Tranny/rear gears/tire diameter ALL affect what the motor "wants". Toss in a cam - the cylinder pressures (people call this COMPRESSION RATIO - but that is the WRONG thing to call it) all will affect the timing a motor wants to see.
Having said all of this.... which is why NOBODY can tell you want to set your timing at..... You should look for 10 to 12* at idle... and no more than 36* at 2400 or 2500 rpms with the vacuum line to the vacuum advance disconnected and plugged. Reconnect it when you're done.
Go out for a nice road test -- listen to the motor - for "pinging" under "load" --- so drive it UP a hill and try to lug the motor down. The minute you hear pinging STOP LUGGING IT by selecting a different gear or whatever you have to do. YOU CAN HURT THE MOTOR running with pre-ignition (pinging). Go cruise on the highway -- light throttle pressure - hold steady - try to see if there's any "bucking" or "surging"..... and then just do "seat of the pants" driving if you don't have pinging and you're not surging then just see how it runs and drives.
Remember as your timing is advanced your idle rpms go up - so you'll need to reset that and then check your timing again etc. Also -- as the rpms change - you may need to tweak the idle adjustment screws on the carb.
Best idle adjustment will give you the most rpms and the most VACUUM as read on a gauge... I use a timing light that gives me rpms and I always adjust a carb idle with a vacuum gauge and the timing light (for rpms).
Old 12-02-2010, 12:08 PM
v8s10kid's Avatar
thanks alot for the info
Old 12-02-2010, 01:07 PM
You're welcome.
I'm not trying to make it seem "insurmountable" either -- but I always feel that people that are "informed" can usually do a better job....
Forgot that you mentioned your timing tab. There is only one way to ABSOLUTELY KNOW if your timing marks line up correctly.
Get a piston stop.... they can be bought from summit etc or borrow one.
Pull ALL the plugs out.
Open the throttle to wide open.
Put the piston stop in number one plug hole.
crank the motor over MANUALLY with a wrench on the balancer bolt -- DO NOT ATTEMPT TO TURN IT OVER WITH THE STARTER MOTOR!
This exercise is taken EASY -- don't attempt to JAM the piston into the piston stop... your pistons are aluminum - the piston stop will bend etc... so be gentle - turn it over nicely until you feel it bump up against the stop.
When it stops = make a mark on your balancer with a grease pencil or chalk etc where the ZERO is on the pointer. Rotate the motor the OTHER direction. When it stops make a mark on the balancer wherever the ZERO is on the pointer.
EXACTLY HALF WAY BETWEEN THESE TWO MARKS IS TOP DEAD CENTER.
So if you rotate the engine to line up the zero on the balancer and the zero on the pointer -- and they line up exactly half way in between your two marks you're good to go.... if not.... Then either the balancer is wrong or the pointer has been bent or is the wrong one etc. At least now you know your timing is either spot on or it's a mess that needs fixing and you can't trust it.
Old 12-02-2010, 05:12 PM
v8s10kid's Avatar
good to know. now i just need a timing light and a piston stop.
actually, summit gave me a $20 credit when i ordered my carb and stuff .
Old 12-08-2010, 10:20 AM
v8s10kid's Avatar
its a bit cold out but i finally decided to suck it up and check a few more things before i go spending $ all crazy like. holleytv.com gave me a few starting points
fuel filter - good
air filter - looks good but will run it without it to double check
egr valve - dont have one
alt voltage - good (at battery:12.9 volts when off, 14.8 volts when at idle)
as i was checking the alternater to see if maybe the ignition system wasnt getting enough voltage i could hear a metallic sound coming from the passanger side valve cover. not a constante noise but you could hear it every now and then. oil level is a bit low, im hoping its just a rocker not getting enough oil or that has too much lash.
ill have to check the valvetrain when i get home later
