Old 03-16-2010, 08:51 PM
fakesnake.com's Avatar
fakesnake.com fakesnake.com is offline
Default Brand new Wilwood Brakes for Ford Set up- 9" rear and Mustang II front end
Abandoned one of my projects. I know you guys are mostly Camaro guys but for any Ford guys I have a brand new Wilwood 9" small Bearing, 2.5 offset rear-end brake kit- 4 piston and 13" rotors cross drilled/slotted. Part number 140-9220-D. Retails- $1905.96, Summit sells them for $1701.95. Will sell for $1,500+ shipping. Have assembly instructions. I took out one of the rear rotors to mount to wheel for fitment only. Rotor has some dust from sitting that will dissapear once you run brakes.
Brand new Mustang II 6 Piston Brake kit with 13" cross drilled/slotted rotors. Part number 140-7018-B. Retails for $1,892.24. Summit doesn't list them but would probably sell for $1,700. Will sell for $1,500+ shipping. Have instruction manual.
Located in So Cal. Here's a pic of the rear set up which I have out of the box.
/wilwood.jpg[/URL]
www.fakesnake.com
1962 Mercury Monterey Convertible
Old 05-02-2010, 06:02 AM
daryld daryld is offline
Interested but need more info. Just bought a 68 fastback custom with a tubular mustang II subframe and narrowed moser 9" in the rear. New at all this. Need to know if this will work on my car? PM me with your # so we can talk, if you still have them. Thanks
Old 12-04-2010, 07:52 AM
Lowfast's Avatar
Lowfast Lowfast is offline
Interested in the fronts if you still have them. Let me know.
