Old 01-08-2011, 04:51 PM
Motorcitydak Motorcitydak is offline
Yep, there is. That was my first place to start looking for parts. Ive been trying to find em for it and for the life of me, I cannot. I do know a few things about it. The front diff goes thru the oil pan. Also, the 5.7 Hem in the LX platform(300, charger, est...) gets a mercedes transmission. A Wa580 or something like that. Its overly complicated and not conducive to modifications or being swapped into some other platform. From what I can find, the transfer case in those cars may be the same as the ones in the SRT-8 jeep. A NV147. That is also an overly complicated piece that will not bolt up to my transmission. I need a NV231 or something similar to use in my car
Old 01-10-2011, 06:32 PM
Originally Posted by Motorcitydak View Post
What I do not like about them is that the upper ball joint is built into the knuckle. I want to run nascar type arms that have the ball joints in the arms.
couldn't you just fabricate a plate that bolts in place of the upper ball joint with a tapered hole to fit the upper ball joint that is on the c6 knuckle?
Old 01-12-2011, 11:06 AM
It looks like Im going to have to do that. I was about to buy a c4 knuckle but the hub is held on with a rectangular 4 bolt flange and they are different front to rear. On the c6 parts, they used just about the same hub front and rear. The knuckles have a much larger hole in the center and the hubs use a triangular 3 bolt patter. Im not completely sure on this one, but I think I can take the front STS hub and just bolt it rite into the c5/c6 knuckle. They both appear to be the same size and bolt pattern but I am not positive. That would solve the hub and knuckle issue so then I will just have to figure out something else to do for the UCA.
Im thinking I can use a UCA with the bolt in ball joint. Then maybe sandwich that with 2 pieces of 1/4 steel? AFCO makes em with a 3/8 thick bolt plate so I could also to weld in a 3/8 circle to one of the sandwich plates. That would give the ball joint 7/8 of steel in the UCA to hold it in. Keeping in mind that the UCA does not see all that much force anyways, I think that would be more than enough.
Old 01-13-2011, 10:21 AM
exwestracer's Avatar
exwestracer exwestracer is offline
Try to find a UCA that has the tubes running out past the ball joint centerline, rather than the plate hanging off the end. You don't need such a massive plate if the side loads are going straight into the tubes.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 01-13-2011, 02:31 PM
Who makes control arms like that? I just looked at the AFCO site and was going to get em thru there. Is there somewhere better?
Also, the AFCO ones have a 3/16 flange. Not 3/8 like I thought for some reason. I still could use 2 1/4 plates on that and the 3/16 in the middle giving the ball joint 11/16 of steel to ride in
Old 01-14-2011, 11:56 AM
Just a couple examples.
http://www.howeracing.com/p-7564-cro...pe-4-bolt.aspx
http://www.detroitspeed.com/1967-196...30101-uca.html
I'm sure there are others out there.
(Actually I just went back and looked at AFCOs arm. They are a better design than they used to be. I haven't dealt with theirs in about 10 years. Those shouldn't need a lot of reinforcing either...)
