Originally Posted by Gonzo
Matt came by the shop a few weeks ago & decided that he wanted to add a few things to the Camaro.. Vintage Air, firewall to sub-frame bars, JCG A/C firewall plate.. Right now we are working on building custom oil can that will tie into the valve covers... Also got the approval to give the engine compartment some nice detail...
Cris,
I'm curious about your firewall to subframe bars that you are adding to this car. It doesn't appear that there is a cage in this car, am I correct? If so, do the bars literally just tie into the firewall? Is there enough support in the metal of the firewall to make the bars worthwhile?
The firewall in these cars is just sheet metal with no real support behind it as I recall. So I'm wondering how much actual benefit these bars would be in preventing subframe flex...
I recall seeing somewhere that you make the round adapters that go in the firewall. If so, do you sell those as well? Depending on the answers to the above, I might consider a set for my car, but I won't have a cage to attach to behind the dash...
Thanx!
