Old 01-18-2011, 01:39 PM
67ragtp 67ragtp is offline
Default Need a muffler suggestion
I cant get the corsa db red series muffs since there discontinued. Could really use a suggestion on a muff that has minimum drone. Going behind an LS7.
Thanks Rich
Old 01-19-2011, 05:42 PM
Lateral-g Moderator
Look into Borla.
Old 01-19-2011, 07:48 PM
Thanks Stuart- Im going to assume that you have them on your 69 Ls7, are they reasonably mellow while cruising and do you have full tail pipes out the back.
I just dont want the thing to be obnoxious while cruising a long distance, of course we want it to roar when in the gas.
Thanks Rich
Old 01-19-2011, 10:38 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
Have you heard anything from Spintech? I have them behind my LS1 and I hopefully I will be putting them on my Camaro soon also
TJ Ragucci
http://www.northeastrodrun.com/
Old 01-20-2011, 05:32 AM
Tj - I dont know if there are different styles of spintech, but the ones I heard on a friends 55 were so loud I thought the earth was shaking. I could hear him coming from a mile away.
I think my choices are narrowed down to either borla, magna flow, and stainless works. The question is which one will be the most mellow at cruise rpm.
Thanks Rich
Old 01-20-2011, 05:34 AM
Lateral-g Moderator
Thanks Rich
I like the sound on my LS7 camaro that I had. But they sound good on all the DSE cars that I've driven in. Im sure there are others but Borla is a good sound IMO. Good luck. I think Scott has spintech and they sound good also.
Old 01-20-2011, 05:46 AM
Stuart - Scott has the corsa red series mufflers on his car, I emailed him a week ago. I cant believe they discontinued that package, no doubt a high quality piece, they put a ton of effort into the noise cancellation hardware inside the case. I think it just cost them to much to build it.
Old 01-20-2011, 11:03 AM
DRJDVM's '69's Avatar
I've been looking at the spintechs.... Mostly because I can get one with a 3 inch case. ALOT of people say the spintechs are too loud.... But the issue I have with that is that they have alot of different models ranging from a full race version to a quiet street version. So when someone states they are too loud , it would be nice to know which version they are referring to
Old 01-20-2011, 01:48 PM
Lateral-g Moderator
Scott had Spinntechs at first, my bad. He said they were real loud, and age thing LOL. I wouldn't like loud either, age thing, LOL.
Old 01-20-2011, 01:58 PM
TURBO2276 TURBO2276 is offline
Will CR have an effect on how loud a particular engine will be? Say an ls7 with race gas only level CR as opposed to pump gas CR? Exhaust will be 3 inch with x-pipe. I'm looking for loud obnoxoius hear you from blocks away sound! I want car alarms going off etc! Lol! I don't plan on going on long drives so quiet isnt a factor
