Old 01-25-2011, 07:21 AM
syborg tt's Avatar
Originally Posted by kttrucks View Post
This looks like a great build... even though it isnt a Mustang... Just curious, how are you going to match the profile of the dash to the windshield base? I'm using an 04 Cobra dash in my '66 Coupe, and although it's trimmed to fit, I still have to use some kind of filler to finish it out and was wondering if you're going to use 'glass or some kind of epoxy. I think I can get away with glass but Im looking at options. nice work on the metal replacement.
thanks!
Kevin you need to look at the sn65 mustang. Dave at comp fab did the new dash old car swap. Looked very nice. I will send you pictures tonight
marty-mj
Old 01-25-2011, 08:03 AM
kttrucks's Avatar
kttrucks kttrucks is offline
Thanks Marty!!! BTW I smoked over your truck @ SEMA... freakin wesome! I've been meaning to catch up with you and finally have to time and short term memory to handle it. Are you planning on being at the Nashville Goodguys event? (PM sent)
KT.
PTFB, Viking, Holley Performance Products, BFGoodrich, Heatshield Products, Turbonetics, Hellion Turbo Systems,TCI, Dennys driveshafts, Eastwood, Preferredline Media, Summit Racing, Strange Engineering, Forgeline, TMI Products, DBR High Performance, Spectre Performance, Vintage Air, NPD, Digitails, Redline Lumtronix, Dakota Digital, Newport Engineering, Stage 8 fasteners, Industrial Depot, Brian Finch, Grant Salter, and many more Good friends with big hearts.
Old 01-31-2011, 06:05 PM
64skylarkls1 64skylarkls1 is offline
Default Awesome!
We've talked on a couple other threads as I'm doing the same LS conversion into a 64 Skylark conv. Man, your not afraid of much! Great job on a huge project! Cudo's to you for keeping up the build thread.
I would say I'm about where your at with the LS coversion although I don't have all the body work to tackle as you do. Love the tailights, very cool. What do you plan on doing for headlights and steering wheel? From what I'm getting from talking with Grant, you can't get a steering wheel for this airbag column.
Went to a local car show this past summer and there was a guy who took the shell of a Camaro like yours and grafted it to a 97 Firebird chassis. The car looked awesome, so I've seen that dash in an older Camaro before. He had to make up the chassis length difference in the front fenders. It was his first show and he took home a well deserved trophy.
Old 01-31-2011, 07:47 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
grant is correct, you cannot get an adapter for an air bag column. they say that because they can't sell you something knowing you will remove your air bag. since your not using air bags in your car you can use grant adapter GRT-3196.
i'm not sure what i am going to do yet about a wheel i am thinking i will just run the stock 4th gen wheel because i have steering wheel controls.
as for head lamps i have a set of HID from a nissan that i am going to convert.
Old 02-01-2011, 10:32 AM
The adapter kit you mentioned will fit the 02 spline? Grant said it was special. Also, is there any way to know for sure that the black housing bell will match the 4 1/4" column diameter of the 02? I've had a Classic Grant wheel for some time but the bell is 1/2" small on the diameter.
Thanks again. No doubt you're going to have a very nice ride when it's done.
Old 02-01-2011, 10:46 AM
CamaroAJ's Avatar
no idea. i did a google search and found that on LS1tech about a '98. i don't remember there being anything special about the spline.
Old 02-08-2011, 11:16 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Awesome build!
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 02-09-2011, 04:40 PM
CamaroAJ's Avatar
Originally Posted by Tuske427 View Post
Awesome build!
Thanks!
Old 02-13-2011, 06:51 PM
CamaroAJ's Avatar
small update because i had a small side project to get done first.
got some 16g and 18g sheet metal and made a steel box to block of the driver floor vent. since there is a lot of room behind it i figured it would be a great place to mount the throttle position controller for the traction control. fully TIG welded and smoothed.
Old 02-13-2011, 08:07 PM
coolwelder62's Avatar
Look's good.That's a neat Idea for a place to put things.
