Old 02-01-2011, 02:20 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Default LS Throttle Body Question
For all you guys that have done LS swaps, what have most of y'all went with as far as throttle body's...DBW or cable driven? Any benefits to one over the other? Right now, my motor is still in the crate. I have a cable driven throttle I'm planning on going installing, but I'm curious about the DBW.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 02-01-2011, 03:44 PM
Ron in SoCal's Avatar
Hey Marcus - I'm only in process so I have no real world observation yet, buuuut...
cable = rounting and potential repair if it breaks
DBW = slight delay so I've heard
Also, I believe you'll need a Nick Williams if you decide to go 102 with your FAST intake. I'm going DBW...
Ron in SoCal
69 Camaro in progress
Old 02-01-2011, 03:51 PM
Stielow's Avatar
Stielow Stielow is offline
TBW with a GM Crate harness works great!
Mark
Old 02-01-2011, 03:54 PM
scherp69's Avatar
scherp69 scherp69 is offline
I've read quite a bit good about DBW. I like the idea of the DBW as I was able to smooth my firewall and delete the cable. I'll be using the Nick Williams 102mm DBW one. They look sweet.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 02-01-2011, 04:12 PM
JayR JayR is offline
Lateral-G Supporting Vendor
I've heard of DBW delays too and there's a company that makes a chip that goes in-between the pedal and the weather pack that connects to it but I've also heard the delay is far less of a problem with GM LS TBs. I don't have a ton of experience with all the other DBWs but I can't sense anything in my GM unit.
Having said all that, I like mine.
Old 02-01-2011, 06:25 PM
MattG's Avatar
MattG MattG is offline
TBW is the only way to go. Those chips to enhance throttle response are only a bandaid and a competent tuner will make it feel just like cable operated, only better.
I have a 24 tooth DBW computer and harness from speartech With cruise control. My tuner is Ed at Virginia speed and he cleaned up the lazy throttle problem that you have heard about. The cruise control works great and last but not least it cleans up the look of the engine.
I will never go back to cable, but once again, without a good tuner you could possibly suffer a disconnected feeling as far a throttle response depending on your engine setup.
Oh yeah, I understand it is more difficult to set up cruise control with the 58 tooth computers if your curious.
Hope this helps...
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 02-01-2011, 06:52 PM
The LS2 I installed in the '55 post I built for a buddy was DBW... was super easy to build a bracket for the throttle and it just plugs in... and worked perfectly. Can't get much easier or better than that!
Less cables and less linkage -- is all good in my book.
Old 02-01-2011, 07:52 PM
Datsbad's Avatar
Datsbad Datsbad is offline
As someone who has driven Matts car above I'd say the exact opposite of him .. I'd only prefer the cable . Response is much better and not as much to deal with mounting the throttle pedal.
Also none of that "reduced engine power " mode if your tuner doesn't have it right .
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 02-01-2011, 09:20 PM
214Chevy's Avatar
Thanks guys. Anyone know of any good tuners in Dallas? I've heard LG Motorsports is a good company. Any others? What I don't want to do is get DBW and cannot find a good tuner and have the car not being fun to drive due to it not being tuned correctly.
'68 C10 swb
'72 Chevelle
Old 02-01-2011, 09:36 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is online now
Originally Posted by MattG View Post
I have a 24 tooth DBW computer and harness from speartech With cruise control. My tuner is Ed at Virginia speed and he cleaned up the lazy throttle problem that you have heard about. The cruise control works great and last but not least it cleans up the look of the engine..
wait, you can do that? You mean that LS1 in my garage might work for me? I was getting rid of it because I want DWB and cruise control (and a 4l80e). Snap, you might have just saved me time & $$
Scott from NJ
