Old 02-22-2011, 08:35 AM
ChevelleNV's Avatar
ChevelleNV ChevelleNV is offline
So are you gonna be selling these as weld together kits, for the guy who wants to do all the welding himself and save some money?
Greg R.
LSX Concepts
Old 02-22-2011, 08:46 AM
ironworks's Avatar
Once I'm convince they can be put together buy "any do it yourself'er". I have some people testing the Tri-5 version currently. These are just the first production models of the Chevelle unit.
Old 02-22-2011, 10:30 AM
ChevelleNV's Avatar
Ill tell ya what, send me one for a 72 Chevelle and Ill put it together and test it out for ya....
Greg R.
LSX Concepts
Old 02-22-2011, 11:07 AM
brandon8350 brandon8350 is offline
This looks great .Like a big puzzle
Old 02-22-2011, 11:25 AM
rwhite692's Avatar
Rodger that looks great, I think the market is going to respond really well to it.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 02-22-2011, 01:26 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
What are some of the advantages of all the individual laser cut pieces welded together vs. the more traditional bent rectangular tubing style?
Very impressive by the way, as is all of the stuff from you guys.
Erik
69 Camaro
Old 02-22-2011, 02:25 PM
ironworks's Avatar
The advantage is you are able to build a frame rail or part to fit up to a given not flat or formed piece very tightly. It allows you to build a chassis like the original stamped unit on a much cheaper scale then have parts stamped or hydroformed. Sure a chassis like this costs more and there are chassis out there being manufactured that are out of a nominally available rectangular or square tube that work but they then have to hang further below the chassis or have a shorter beam height thus reducing the strength of the frame. We reduced the beam height to improve ground clearance further and keep the same strength or be stronger that a thicker frame just through design. We set out to build the strongest most well engineered chassis and then after we had a product we though was good enough figure out how much to price it at. I'm not concern if other frames are cheaper. Alot of frames in the marketplace are. But make our do things the others cannot because they are built out of a piece of rectangular tubing. Our frames are stronger and sit lower with more ground clearance then any chassis on the market.
Hopefully this babble session answered your question. If not let me know
Old 02-22-2011, 07:42 PM
nic's Avatar
nic nic is offline
Love the chassis
Makes me want to build a Chevelle next or maybe a GTO......
Old 02-22-2011, 08:29 PM
Bryce Bryce is offline
That chassis is bad@$$. I am a design/test engineer by trade. Everything I do is tabbed and slotted it makes it almost self jigging. Great work.
What do you use for stress analysis?
Old 02-22-2011, 09:28 PM
ironworks's Avatar
Eric is having one of His rocket scientists work on that for. So the same guys that approve parts for the moon and fighter planes at PDT, will approve this frame for street and track duty. More on that to come very soon.
