Originally Posted by RECOVERY ROOM
Just wondering why the side rails have a angle on the top portion of the frame when other frames don't.Will it make the frame fit different to the car. I'm not even being a smart a$$ with that question
Bill is correct it will fit the body better, which in this case allows the rails to not hang below the chassis as much. But with the way these rails are assembled it makes them stronger then just a piece formed to that shape. Because the body mounts have been boxed from top to bottom thus creating a whole triangulated structure. Then with the round tubes running completely through the rails and into the inner frame section it ties those pieces together using the whole mass of each rail not just the inside surface. The draw back to this design is the mount of welding, but since we have taken advantage of some trick press braking techniques it will cut down the weld time considerably.
Alot more to come in the near future.
