Old 03-11-2011, 10:30 AM
anarchy99 anarchy99 is offline
Default anyone running a kenne bell on an LS1?
I was thinking of swapping out my procharged SBC after I get off deployment to a built LS1 I've got from another project, and topping the engine with a 2.8 kenne bell. I mainly want a fun street car, so off idle power, etc. I tried searching but really can't find anyone running a kenne bell on an LS engine. Thanks in advance.
Jim
Old 03-11-2011, 11:57 AM
I have a friend that has one on his 2010 SS...So on a LS3. What power goals are you trying to attain?
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 03-11-2011, 07:19 PM
Grnova's Avatar
Grnova Grnova is offline
I will be running one on my Nova.
It is a Ls2 With a 2.8h KB
Old 03-12-2011, 10:55 AM
That is a beautiful setup. Looks to be exactly what I would like to do on my car. As far as horse power numbers, I'm not sure. My LS1 is built for boost and around 8:1 compression ration, so I'd probably crank it up pretty good.
grnnova, did you just order one of the corvette kits from kenne bell?
Old 03-12-2011, 09:15 PM
Grnova's Avatar
This was actually a truck kit they are almost identical I modified the bracket and used Kwik brackets for the Alternator and A/C. I am looking at 12 to 17 lbs of boost.
Old 03-13-2011, 09:59 PM
Rick Giles's Avatar
Rick Giles Rick Giles is offline
That is a good looking setup! How much power do you think it will make? Would the Kenne Bell work well on a stock LS2?
Old 03-14-2011, 12:43 AM
parsonsj parsonsj is offline
Project Unfair is using a 3.6L Kenne Bell supercharger. Check my signature below.
John Parsons
Old 03-15-2011, 02:17 PM
Also running the 2300 Kenne Bell On Patrick's 68, nasty sucker it is. LS1, cam only, 565HP at the tires.
Frank Serafine
