Old 02-07-2006, 03:52 PM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
Originally Posted by Speedster
It goes without saying your motor mounts have to be in good shape too.
Brand new Polyurethane mounts
Thanks for the help, I was afraid I'd have to buy some expensive braided lines, and my budget can't take much more abuse
Old 02-07-2006, 07:47 PM
race-rodz race-rodz is offline
AN fittings are your friend in this case, just remember that they use a single 37* flare. dont cheap out on the hose either, good steel braid hose is rated at 300psi min, not a problem with your 60 or so psi from the efi pump
Old 02-07-2006, 07:57 PM
Musclerodz's Avatar
If you run hard line to the engine, put a coil in the line. The extra line gives it some flexibilty. We have done this for years on vintage aircraft. The other thing to do is to make up steel braided lines with high pressure fittings on each end.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-07-2006, 10:41 PM
907rs's Avatar
907rs 907rs is offline
Mike
Yep, what Mike said. I don't care how stout your motor mounts are, without some room in the lines for deflection you're asking for trouble sometime down the road, Derek.
Bill
Old 02-08-2006, 06:12 AM
Derek69SS's Avatar
Thanks for the help.
What cars had a filter I could use? All the later model cars have the plastic lines that clip together, so I'd assume I need to look for something in the 80s that would have still used steel lines, and had fuel-injection.
Old 02-08-2006, 07:36 AM
130fe 130fe is offline
Post Fuel filter
Derek, you can use a LT1 F-body fuel filter. All you need is AN6-16mm oring adapters (2) to plumb it into your system like these #5100 http://www.performanceplumbing.com/FuelPieces.html . I have also seen them locally at a napa autoparts store. If you are looking for some bling, S&P has a nice filter bracket setup. For a more cost effective route, just get one from your local parts store and fab some brackets. I have mine mounted near the gas tank. Hope this helps you.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 02-08-2006, 07:49 AM
Derek69SS's Avatar
Yes, it does - THANKS!
I'll mount the filter in the rear by the tank, and use all hard-lines there too, so if I need for any reason to drop the tank, I just have to detach the line from the filter, and the one going back to the pump can just come out with the tank.
