Old 04-24-2011, 08:20 PM
scherp69's Avatar
scherp69 scherp69 is offline
As always Chris...amazing work. A question for you though with the distribution block. I haven't gotten around to running my fuel lines, and am really not sure about plumbing a fuel injected car...but just wondering if that works with a return line. Would that work with a Rick's tank with in tank pump? I thought I've read that a Rick's tank needs a return line that's why I'm asking as I like those blocks.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 04-25-2011, 05:17 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Great looking work and great looking fuel components Cris.
Old 04-26-2011, 07:42 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Mike-
WE are currently using the Rick's tanks with the Vaporwoks trays that use the 2010 Camaro fuel module.. What I like about it is that it requires no fuel return system & can support about 600 hp..
Here is a pic with the Rick's gas tank with a return system that we used a Aeromotive fuel regulator to loop it back to the gas tank on the Firebird..
Thanks Tony!
Cris Gonzalez
Old 04-26-2011, 08:03 AM
bentfab's Avatar
bentfab bentfab is offline
WOW ! Those dis. blocks look real familiar ?
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 04-26-2011, 04:16 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Cris,
What brand are those black AN fittings and hose? Does that hose have the Teflon liner?
Erik
69 Camaro
Old 04-26-2011, 05:32 PM
scherp69's Avatar
Originally Posted by Gonzo View Post
Mike-
That's a cool way to do that. Definitely saves having to run the extra line the entire length of the car. I'm going to save that picture that in my 'ways to do things' file. Thanks for posting that.
Mike
New Gen Splitters
LS3 and TKO600
Old 04-27-2011, 08:18 AM
Cris@JCG's Avatar
They might have some similarities to yours or other in the market.. but we make them to what we require here @ the shop.. For the most part it is easy for us to make any custom fitting or distribution blocks for fuel, brake, or A/C..
Erik- We use Summit brand fittings & hoses.. They are private label by one of the top manufactures of fittings & hoses.. We save a few bucks by using Summit brand fittings.. Custom plumbing can be expensive.. No teflon liner on the hose..
Originally Posted by ErikLS2 View Post
Cris,
Good to see that it helped you Mike..
Cris Gonzalez
Old 07-22-2011, 11:57 AM
Cris@JCG's Avatar
The Firebird has been getting a serious nose job!! It has been allot of work to get the lines as good as you see them in the pics.. got more coming! billet honey comb inserts that will bolt on to the orginal plastic headlight grills.. We even machined some mock up pcs...
The cold air box is almost complete.. Machine shop should have one more piece I need to complete it & mount it...
Cris Gonzalez
Old 07-22-2011, 01:56 PM
70rs's Avatar
70rs 70rs is offline
Wow Cris, super nice lines on that beak. I have seen & heard how hard it is to get those noses all dialed in. that one looks really good.
Eric
Old 07-22-2011, 04:53 PM
Another great job and car Cris. The cold air intake looks cool.
