Old 05-03-2011, 06:42 AM
wedged wedged is offline
Originally Posted by scottysimp7 View Post
I hope you leave the body as is. I like the rat rod look.
the body will stay as is except for some patches to make th e cab water tight.
You just need a pack of smokes rolled up in your sleeves and some pomade for the dew! Nice!
That will never happen. cigarettes are disgusting and I'm not some costume wearing poser.
Old 05-03-2011, 07:31 AM
elitecustombody's Avatar
I like
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 05-06-2011, 08:48 AM
KlasSic68's Avatar
KlasSic68 KlasSic68 is offline
Looks sweet! I like it
Justin M
1968 C-10 short fleet 2wd
2011 WRX STi sedan - DD
Old 05-16-2011, 12:55 PM
PonchoJohn PonchoJohn is offline
I lost track of this build for a while... looking sweet!
Old 05-18-2011, 10:51 AM
Q: for ya- what size are the holes that are drilled in the 18" steel rims? I 'think' they may match up to my Dodge 20" steelies for a rubber rake while allowing a little bit of tire to be mounted. <fingers crossed>
Old 05-19-2011, 12:40 PM
the holes in the rims are 1.30" .
Old 05-20-2011, 09:46 AM
Thanks!
Old 05-20-2011, 12:26 PM
Dr G's Avatar
Dr G Dr G is offline
I agree that keeping the patina will be tres cool. You can't recreate that.
Gustave
Old 05-27-2011, 02:41 PM
Boxed the small section of dakota frame that was not boxed. This made the entire frame a whole lot more rigid. I'll probably add some gussets to the corners where the rear half meets the cross member once I put the loop and the exhaust ports into the cross member. The piece of green box tube is just temporary. the trans tailshaft is resting on it and it also kept the rails the correct distance apart.
Old 05-27-2011, 06:28 PM
ArisESQ ArisESQ is offline
are those front wheels the ones you'll be using? personally i think a larger diameter wheel would look better and match the rear nicely. style is on point though.
