Old 02-08-2006, 07:49 AM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
Originally Posted by 130fe
Hope this helps you.
Yes, it does - THANKS!
I'll mount the filter in the rear by the tank, and use all hard-lines there too, so if I need for any reason to drop the tank, I just have to detach the line from the filter, and the one going back to the pump can just come out with the tank.
Old 02-08-2006, 10:02 PM
lt1 chevelle's Avatar
lt1 chevelle lt1 chevelle is offline
for my lt1 iam using this set up but iam running bradied line from my tank to the fuel rails it may cost a lil more but in the long run it will save u and also it looks very clean. if u dont go with a fairwall mounted fpr they make a kit u can put fittings on the old lt1 style regulator that will allow u to run AN fittings i will try a look for that site.
Old 02-09-2006, 06:53 AM
Derek69SS's Avatar
I'm keeping the stock regulator for now... I was planning just to cut and flare the stock lines - bad idea???
Thanks for the help
Old 02-09-2006, 08:38 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Even easier and more simple is to get a fuel tank from a 95-96 (late model Caprice) and install it in your car. It has the pump built in. Then, use the factory stock plastic Caprice/Impala fuel lines from the tank to your motor. This is how I plumbed my 69 Camaro. Works great, is safe, reliable, and easy to hook up without having to mix up all kinds of aftermarket connections, etc.
Old 02-09-2006, 08:57 AM
Derek69SS's Avatar
It's about 1/4" too wide to fit between the Chevelle rear frame
Old 02-09-2006, 09:25 AM
69MyWay's Avatar
You can use a heat gun to reshape the tank. If you only need 1/4", you could easily heat the tank and apply pressure until it rolls in a tad on each side.
