Old 05-21-2011, 09:25 AM
rat_rod_russell's Avatar
rat_rod_russell rat_rod_russell is offline
Yes, yes I do Skip, So I rejected that last frame due to a lack of turn in clearance but I think I've solved that problem Behold V5.4 and I'm almost done with the front stub, Check out the update
Update
2011/05/21
So I’m almost done with the new frame front section. Right now it looks to be right at 101.26 lbs. I’m looking for more room I can lighten the front up without losing structural integrity. I still need to add the rear shock brace and the sway bar hole so I look to pick up another 3-4 lbs there and I’m figuring on 2-3lbs of welds. The old one was just over 75lbs in the computer but I didn’t have all the parts drawn so probably closer to 85lbs with those parts and welding wire.
We now have a full 34 degrees of turning radius with 275/xx/Rxx Hoosiers. FYI Hoosiers have a serious edge on them making them almost .300” wider than a normal 275, So I can probably run 295 Front tire on this configuration and still turn around in 2 lanes without punching on it.
Flaming River Rack and Pinion, BIG thanks to those guys for sharing a part file for my design I drew one off the rack I had but there are too many compound angles and I screwed up a little here and there. We now have a much beefier rack up front to take the load and its only 2 lbs heavier than the C4 corvette rack I was using.
PFADT’s superior upper shock mount with their Coilover shocks. I love the OE Pfadt shocks I have already, the map is great and I plan on keeping them. But with some serious luck I’ll be able to get a set of these for my truck, http://www.pfadtracing.com/catalog/p...7606d692d513ba this will shave some weight from the suspension and most importantly the un sprung weight and I’ll be able to dial in my compression and rebound independently which will be important when I get back on the track.
I’m waiting on a visit from these guys http://www.absolutegeometries.com/ My plan is to scan several portions of the body into a 3D point cloud so I can drop it into the computer and overlay it with the truck to make sure we have clearance. Here are some video for you guys who have never seen one of these 3D scanners at work.
https://www.youtube.com/watch?v=oZKrwkzO6-w https://www.youtube.com/watch?v=ywFb-FnT8rA
More coming soon
Later
-Russell
PT-57
1957 Chevy Truck, 6.0L LS, T56, STS Twin Turbos, C6 Corvette Suspension, CAD Designed Frame by Hot Rod Jim's.
https://lateral-g.net/forums/showthread.php4?t=20292
http://www.nerdrods.com
