Old 02-11-2006, 12:43 PM
third base third base is offline
That looks kind of familiar? I used 1970 cuda exhaust tips though. Looks good!
Old 02-11-2006, 12:45 PM
Datsbad's Avatar
Datsbad Datsbad is offline
cool , I am glad you like it , means alot since you guys are doing the best exhaust set up i have ever seen on a 69 , got anymore pics you could email me of that thing ?
i understand what your saying but i am thinking i need it to stick out some to prevent any damage to the paint generated by the exhaust tip . whats your take on this . when i do body work do you think the heat will affect anything? remeber this is going to be a car that is used , not just sitting around looking pretty !
Originally Posted by killer69
IMO i would radius the outside to match the flow of the lower QP and round the corners a bit.................... but i really like the idea
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 02-11-2006, 12:48 PM
1970cuda 1970cuda is offline
Default exhaust
maybe a 1970 cuda rear tips might work
Old 02-11-2006, 12:49 PM
Datsbad's Avatar
yours looks way cool , but you have the advantage at some point with that fuel tank . I on the other hand have the advantage of no leaf springs as you do . I sure am thinking of other ways to do the next car . I might apply some of this knowledge to the convertible when i get to that point .
also, will your tips sit close to the paint? think it will harm it?
since I dont have a narrowed tank , I am limited to the size . If i had a custom narrowed tank I would have a much better chance of getting away with more room without the leafs also , that would make for the most room . or even better a fuel tank in the trunk , I personally am no fan of fuel cells in the trunk .
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 02-11-2006, 12:52 PM
Default typing
boy i must post really slow lol
Old 02-11-2006, 12:54 PM
Datsbad's Avatar
no problem , Its the thought that counts right ]?
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 02-11-2006, 02:57 PM
Putting a fuel cell in was an advantage, but, I would never do it again. My tips reveal is about 1/8"-3/16" away from the paint. I don't think that the tips will get hot enough to damage the paint. I was warned by others not to run them totally flush though. This because of the exhaust itself, and the fear of carbon deposits forming on the paint. I wasn't too worried so I went against the warnings and did it anyway. I didn't want to compromise the look. I figured it would be an easy fix if it did happen. I think you will be fine. Keep us updated.
Old 02-11-2006, 03:45 PM
BC69's Avatar
BC69 BC69 is offline
I like it! What are you going to do to prevent it from rattling? Is there any noise issues with it so close to the panel, or heat issues?
Tim
In memory of those gone before us
In gratitude for those who care.
Old 02-11-2006, 04:08 PM
Steve1968LS2's Avatar
What about some sort of thermal coating?? (instead of powder)
Looks cool.. would be bit worried about the heat though..
Old 02-11-2006, 04:13 PM
Speedster's Avatar
Speedster Speedster is offline
Another possibility for this setup is to make "a box within a box". In other words have an air gap between two rectangles to act as a heat sheild. The other possibility is to make the cutouts in the rear valence large enough to allow airflow around the exhaust to try to keep the heat reasonable.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
