Old 05-26-2011, 05:35 PM
MARK WHITLOCK MARK WHITLOCK is offline
Default Ls upgrade
Looking to upgrade a ls2 to ls3,6 or 7 for autocross. I'm thinking to go for 500 foot pounds and super response. Any suggestions on builders? Kaytech, Thompson any others. Thanks for your help, Mark
Old 05-26-2011, 05:39 PM
rogue rogue is offline
with $15k, buy a spec miata and DOMINATE the good guys autocross
http://www.texas-speed.com/shop/
Old 05-26-2011, 05:46 PM
HP is not your main concern in autocross.
Old 05-26-2011, 05:53 PM
The men on THIS forum don't drive Miatas....
Old 05-26-2011, 05:54 PM
HAHAHAHAHAHAHA coming from you.... that's FUNNY!
Old 05-26-2011, 06:41 PM
coolwelder62's Avatar
Kevin Miller's 69 camaro has a stock 80K LS1 for power. Texas GG autox.Brian Finch 33.755 Kevin 33.945.Nashville GG autox Brian Finch 33.142,Kevin 33.352.Brian Finch 550hp,Kevin 325hp.And Nashville was only Kevin's 3rd autox in his newly finshed camaro.Might be a little bigger gap on a long road course. Way to go Kevin.Mark I don't think you need a bunch more power unless you guy's are wanting to run some real fast long road course's.
Old 05-26-2011, 06:50 PM
Default Ls swap
Most will be SCCA or Goodguys auto with some Road Atlanta and Barbers. I think a little more will help, just looking for a second or two. I think the rear end repair wll help a bunch, We may wait and run it first. God Bless mark
Old 05-26-2011, 07:12 PM
I'd be looking at a Mast setup I think. However Katech would be the cat's meow but I can't afford to look .
John
'71 Nova (Build thread)
FFR Roadster
Old 05-26-2011, 07:19 PM
ccracin's Avatar
ccracin ccracin is offline
Default Wegner Automotive
I would suggest Wegner Automotive. Check out the thread in my signature for the video of our dyne run and sheet. Almost 550 ft# and 7000rpm capability! Just sayin!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 05-26-2011, 07:21 PM
Originally Posted by coolwelder62 View Post
Kevin Miller's 69 camaro has a stock 80K LS1 for power. Texas GG autox.Brian Finch 33.755 Kevin 33.945.Nashville GG autox Brian Finch 33.145,Kevin 33.342.Brian Finch 550hp,Kevin 325hp.And Nashville was only Kevin's 3rd autox in his newly finshed camaro.Might be a little bigger gap on a long road course. Way to go Kevin.Mark I don't think you need a bunch more power unless you guy's are wanting to run some real fast long road course's.
Kevin is a hot foot or your chassis is that good. Maybe both... 200hp would put him ahead of Brian if he can control it.
