Old 05-31-2011, 07:39 PM
millertime179's Avatar
millertime179 millertime179 is offline
Originally Posted by DJW32 View Post
What size are the front and rear tires? 275 & 335?
Any chance we can get some pics of the rear suspension?
Great looking car!
the fronts are 275/40/17 and the rears are 315/35/17. there should be some pics of the rear suspension earlier in this thread or you can check out shannons thread under chassis and suspension (scott mocks rear suspension)
kevin
Old 05-31-2011, 09:32 PM
Jr's Avatar
Jr Jr is offline
This thread doesn't have any pics of the rear suspension. Modo's thread doesn't have any installed pics, either.
Old 06-01-2011, 05:41 AM
coolwelder62's Avatar
I will get Kevin to bring his car over to the shop and we will get some photo's of the car and the rear suspension up on the lift.So everybody can get a real nice view.
Old 06-01-2011, 07:19 AM
Rick D's Avatar
Rick D Rick D is offline
Cool Scott looking forward to seeing it installed!!
Rick
Old 06-01-2011, 09:46 AM
syborg tt's Avatar
Hi Kevin,
Car looks great
I do have a question.
What exhaust manifolds are on the motor ?
marty-mj
Old 06-01-2011, 11:36 AM
Hi Kevin,
Car looks great
Those are the stock LS1 manifold's.W/jet coating.
Old 06-01-2011, 03:45 PM
Hi Kevin,
Car looks great
they are just stock manifolds off a 98 trans am. they are tube welded together instead of cast iron so i had them jet coated and just used them for now to save a little money. hoping next winter to do a little motor work and then ill put some headers on it.
thanks kevin
Old 06-05-2011, 07:24 PM
gasfumes gasfumes is offline
What motor mounts and adapter plates used on subframe?
Old 06-06-2011, 03:14 PM
the motor mounts are energy suspension poly mounts and we machined the adapter plates out of aluminum.
kevin
Old 10-11-2013, 09:12 AM
Jr's Avatar
Jr Jr is offline
Kevin,
Did you upgrade the front suspension in the 69? If so, do you have any pics? What size wheel tire did you fit in there?
