Old 06-07-2011, 02:40 PM
240RR 240RR is offline
Got it stripped down to the shell. Next up is bracing it up and cutting out the floor and off with the front clip
[IMG][/IMG]
Old 06-13-2011, 01:57 PM
Rough hacked off the front clip and now will start bracing up the shell to cut the floor and firewall out.
[IMG][/IMG]
Jig is done except for a few more cross beams. Will probably permantly weld two on the ends and the rest will be placed once the shell is on the jig and I start laying out chassis tubes.
Everything is within .1 degree of level and 1mm from square...width is spot on, so I have a good starting point. Was really suprised to get it all that close!
[IMG][/IMG]
Old 06-17-2011, 07:14 PM
aussiebj's Avatar
aussiebj aussiebj is offline
Z cars rock keep the motivation level high....
Old 06-21-2011, 01:09 PM
set the shell at ride height and started taking measurements for the chassis. Jig is done and ordered tubing today for chassis.
[IMG][/IMG]
Old 06-21-2011, 02:50 PM
70rs's Avatar
70rs 70rs is offline
Not much left! Very cool project.
I am waiting patiently for you to finish it.......lol!
Eric
Old 06-21-2011, 03:21 PM
yeah...should be done tomorrow
Old 06-21-2011, 04:19 PM
70rs's Avatar
Sweet! I expect a full report from the track......with video.
Eric
Old 06-30-2011, 11:08 AM
Default chassis start!
Here is the start and the basic layout of the chassis center section. I ended up going with 1-3/4" 14 gauge (.083) mild steel for the bulk of the chassis. The cage will probably be 1-3/4" x .090 DOM
I have a blueprint from a GT chassis and that is what they used so figure I should be safe as long as it is properly built and triangulated and such.
Waiting on a couple of Ebay axles so I can make sure I am OK on the track width before getting too far into the rear clip...which is next up.
I talked to a shop in Florida that said they can modify the 5 bolt output flanges to fit the 6 bolt 350z hubs. I ordered a Q45 and a 350Z left axle so I can kinda double check lengths and all are compatible.
Started making a fixture for the Q45 diff so I can get it set in place.
rear view
[IMG][/IMG]
front view
[IMG][/IMG]
Old 07-19-2011, 07:25 PM
Default more chassis progress
Making a little progress. Realized I needed a surface at each corner to measure and locate the suspension so tacked on 2x2 plates at the rear corners to start with.
I think I have the diff located...fabbed up an adjustable height fixture for it so I can fine tune it as I move forward with suspension and driveshaft/halfshaft angles. So far I have the halfshaft angles at about 2* down to the diff and I think with that I can get proper driveshaft angles.
Got the rear clip upper hoop tacked in place and an upper rocker tube.
Also decided to add 1-1/2" to the wheelbase at the rear. I will pull the wheelwell back by pulling the quarter back when I widen and modify them. Needed a little extra space between tire and drivers compartment. Plus with widening the body about 7 inches it should not hurt the proportions.
[IMG][/IMG]
[IMG][/IMG]
Old 08-02-2011, 08:56 AM
little more progress...suspension pickup points are kinda suspended awaiting final measurements and attachment points/tubing.
[IMG][/IMG]
[IMG][/IMG]
