Old 02-14-2006, 02:15 PM
Diognes56's Avatar
Diognes56 Diognes56 is offline
That car IS sweet. It should be interesting to see what changes he will be making .
David
Old 02-14-2006, 02:38 PM
groovyjay's Avatar
groovyjay groovyjay is offline
69-70 my favourite 'stang years! Very cool looking machine you've got there Mike!
Old 02-14-2006, 05:58 PM
907rs's Avatar
907rs 907rs is offline
Nasty!!!
Bill
Old 02-14-2006, 06:24 PM
Speedster's Avatar
Speedster Speedster is offline
That is one of the hottest looking Mustangs I have seen in a long time. It just looks bad ! And a '70 - my favorite year.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 02-14-2006, 07:40 PM
67Sally's Avatar
67Sally 67Sally is offline
Very nice!!
W.
William Rouleau
Project PonySnake
Old 02-15-2006, 08:13 AM
fvike's Avatar
fvike fvike is offline
Love the strictly business look! But shaved doorhandles never look right on muscle cars...
1969 Ford Mustang - Build progress - My FQuick site
Old 02-15-2006, 12:59 PM
Steve Chryssos's Avatar
That's one nasty streetfighter. The fabbed console and underhood detailing are pure genious. Nice work.
________________
Steve Chryssos
Ridetech.com
Old 02-15-2006, 03:38 PM
mehal mehal is offline
Default The Boss from Bosston
Hi everyone,
Thanks for the kind words on the car. It's been a long (and difficult) journey with that thing. I thought it was finally done, but as usual my luck turned bad. To answer a few questions:
ENGINE - I blew the motor last September on the way back from a local car show. The engine just simply started running bad, so after limping home I took it apart and found that my billet steel roller cam had busted in two right at the 4/8 cylinder bank. The engine only had about 2k miles, so I spoke with the shop that did the motor and they said it was either a defect from the cam manufacturer (Ultradyne custom grind) or bad harmonics from the gear drive which they warned me not to use! Either way the motor has to be rebuilt. I was originally shooting for more horsepower (600-700), so I might try and do more cubes but stay with a 302 based block and cleveland style heads - just like the original Boss motor (which I still have).
IRS - Ford had the guy who designed the Cobra IRS do a design for the early Mustang. I think his name was Klaus Arning. Anyway, they never put it into production because it was expensive and did not offer much improvement (sounds unbelieveable). A guy in Utah found the blueprints and began remanufacturing them under CTM Engineering. The whole story can be found on http://www.geocities.com/ctmengineering/mustanghome.htm. The short story is that I screwed around with this thing for 4 years before I got it to work right. It is a fairly complicated multi-link, reverse A-arm setup with leading and trailing links. In defense of CTM, I did have them narrow the thing an inch on each side for my big tires and I swapped the original Dana center section for an all aluminum unit. So these changes probably added to my woes. But I learned a lot along the way and after much money and pain, I swore that if I ever did the car over I would put a double A-arm IRS in it if I could find one that would work.
SHIFTER knob - came from Billet Balls (www.billetballs.com) and I had the center painted.
What's next, well in the course of getting the IRS to work, I found out that the rear frame rails on the car are slightly off due to years of smoky burnouts and racing abuse. I did put an 8 pt.roll cage and subframe connectors in the car, but apparently too late. So between needing a new motor, having a questionable IRS and rear frame geometry. I stepped up and ordered a full sheet-metal frame from Darryl Schroeder race cars in Oregon. He's the guy who built the frame for Chris Titus' 56 Speedster and the 55 Newmad Chevy wagon that was famous a few years ago. It will use Corvette C5 aluminum A-arms (Henry - forgive me!) but will have a Ford/Dutchman center section. I'll pull everything else from my current suspension. I've got a few other idea's lined up, but don't want to ramble on here or bore you with the details until I am close.
I've got a few other projects that I'm working on right now, so the Boss won't be back until next year. You'll appreciate the other rides, so I'll figure out how to post some pics.
Thanks, Mike
Old 02-15-2006, 04:04 PM
Default My other projects
Well let's see if the picture thing works.
The first car is my 60 Ford Wagon/Starliner. There is a concept drawing and an in progress shot from last summer. Its got 22s & 20s, Air Ride, Injected 514 Crate Motor, 6-speed, Baers, etc..
The second car is my 57 Ranchero. Also got a concept shot and in progress from last spring. Its also got 22s & 20s, Air Ride, Injected 460 Crate Motor, 6-speed, Baers, etc..
I'll have a web site up soon with these and a few more projects.
Thanks Mike
Old 02-17-2006, 07:34 AM
markss28 markss28 is offline
Mike,
My brother and I are building a 69 fastback. He had wanted to put an IRS in the car, I voted for the straight axle 9inch. Which one in your opinion is the better choice and why?
Never Stay Stock
