Old 06-24-2011, 10:36 AM
orangevert's Avatar
orangevert orangevert is offline
Default Whats a good all around air compressor
What is a good all around air compressor that can run tools and paint, I have 220 in 2 different area of my garage.
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 06-24-2011, 08:02 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
Heres some stuff that may help out.
Thread is off topic but it it gets to air compressors in page 2 and 3
https://lateral-g.net/forums/show...t=27432&page=2
https://lateral-g.net/forums/showthread.php4?t=27843
Old 06-25-2011, 09:23 PM
elitecustombody's Avatar
Eaton is the best value.Get 6.5hp or better. Want to spend a bit more?Buy Quincy,Saylor Beall or Champion,just make sure the electric motor runs under 1800 RPM's and pump under 900. Or if you want to spend quite a bit more, look into rotary screw compressor.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 06-26-2011, 06:58 AM
wmhjr wmhjr is offline
Also, look around to see if you can find any used. I had a compressor for years that was "OK", but not really enough for my purposes. I looked for a while and found a commercial grade used 80cu/ft 7.5hp upright that's built like a mack truck, does 34cfm at 125psi, runs slow and cool, for less than the price of a new consumer grade unit with less than half the performance. You have to be careful to make sure you're not getting a worn out, non-maintained junker. Make sure it's hooked up and you can run it before you buy it, but you can sometimes find deals out there. My old compressor got moved to a barn/storage building I've got which also has 220. Now it's a great utility compressor and my main unit is just what I need for more frequent use.
Old 06-28-2011, 09:26 PM
rwhite692's Avatar
In my case, the best all-around compressor is the one I built myself:
http://www.garagejournal.com/forum/s...ad.php?t=42474
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 07-14-2011, 07:39 PM
orangevert's Avatar
Very nice compressor
Thanks guys..
Kirk
Kirk
Old 07-15-2011, 04:39 AM
dave96dcm dave96dcm is offline
Like mentioned above, good comPressors are at 1750rpm, get at least 15cfm at 90psi, so it will have a chance to catch up and stop even if you are sandblasting etc. I have a ingersol rand (sp?) and I love it, I got it through Grainger.com.
Old 07-15-2011, 11:06 AM
Fluid Power's Avatar
we sell Atlas Copco's. With that being said, get a 3 phase motor and buy bigger than you think you need. 7.5hp and 80 gallon vertical's are nice and will run forever! **EDIT** 3 phase power is difficult to find in residential applications. If you find a compressor, take into consideration the cost of a converter if 3 phase power is not available at the compressor location.
Darren
Old 02-20-2012, 07:12 PM
Sandbagger's Avatar
Sandbagger Sandbagger is offline
Darren
Whats the differance between a single phase and a 3 phase .
I found a deal on a IR 7.5 HP but its wired for 230/460V 3 Phase motor (wired for 230V
Appreciate any help ..
Is this too much RPM ?
Old 02-21-2012, 04:42 AM
3 phase motors are more efficient, they have a more simple design, they last longer and can produce more torque and HP than the comparable single phase motor. With that being said, most homes do not have 3 phase power. Than can be used, but a phase converter must be purchased in order to do so. A phase converter needs to be sized the HP rating of the motor. For the motor on that compressor, you would need a phase converter that would handle the 7.5hp. As far as RPMS go, that is not an issue. If you shop around, a converter for that size motor can be bought for under $250. Just factor that in to the 'deal' when shopping for a compressor. I will edit my post above to make a note about 3 phase power requirements for residential use.
Darren
