Old 06-25-2011, 10:59 AM
ccracin's Avatar
ccracin ccracin is offline
Greg, this story keeps getting worse.... so the question now is: what REAL shop you going to take it to get it sorted out?
I believe it is called "THE SHED"!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 06-25-2011, 12:43 PM
70rs's Avatar
70rs 70rs is offline
Wow.......just wow. I am at a loss for words.
Eric
Old 06-25-2011, 01:29 PM
rjsjea's Avatar
rjsjea rjsjea is offline
That's just careless firing the motor with no oil pressure gauge hooked up......maybe more like incompetent
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 06-25-2011, 01:54 PM
70rs's Avatar
I agree! What I am wondering is how this shop got the "great" reputation they have (had)?
Are they using unskilled workers in areas they really need seasoned vets? Is the management different now ?
How does ANY shop have so many issues and stay in business?
Eric
Old 06-25-2011, 08:03 PM
You got it buddy --- straight to "the shed"!
Everything has been fine this weekend... after I got the lights working. But the engine will need a complete do over. No biggie -- it just might have to get a wee bit more 'umpf'.... EEEEEEEHHHHHHHHHHAAAAAAAAAAA
Old 06-27-2011, 06:51 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Man, sorry to hear about the oil pressure and other problems Greg. It's a good thing you have knowledge about cars and have that "shed". Good luck!!
Old 06-27-2011, 09:08 PM
Thanks! Not to worry -- the motor is actually "fine"... it was a cheap crate motor... and we did pull rod and main bearings and they were PERFECT and coated with oil even after all that. I'm pretty certain it's more like they failed (another epic fail) to seal the intake manifold properly. It only huffs blue smoke after a prolonged deceleration... which is telling me that the intake is then pulling oil in from the valley.
Maybe the "pros" will chime in here -- but that's my "official" diagnosis. It won't take me long to pop that off and do a proper job of it.
Actually - it's the brake lights that really get me to chuckling about the entire ordeal. It's like REALLY?! Such a simple inexpensive 1 minute fix.
I will repeat what I've said earlier though... the craftsmanship is superb. Really.
Old 06-27-2011, 10:06 PM
I wish I had your outlook Greg. My motor has sat for 4 years. Every once in a while I run the oil pressure up with the primer tool while I turn it over by hand but I'm still worried about Murphy's law. Every time I think of it starting the hair on the back of my neck stands up.
Glad it running OK for you.
Old 06-27-2011, 10:15 PM
It's just a whole lot easier when you take the $$ part out of the equation... it can all be fixed. Might be a 'hassle', but it can be fixed. I only get upset because I expect to get top notch when I'm billed for top notch. In this case I got billed for inexperience and amateur hour mistakes then I was billed again for fixing it and then again for fixing it again.
Old 06-28-2011, 07:37 AM
DOOM's Avatar
DOOM DOOM is offline
Greg it has to be valve seals or intake.. Dumb question, do you have any type of PCV system?
Mario
USCOLLISION
