Old 07-01-2011, 11:51 AM
No one will ever see it but the owner will have piece of mind. Priceless!
Old 07-01-2011, 06:35 PM
ssick chevelle ssick chevelle is offline
awesome work, what type of steering wheel is that?
Old 07-05-2011, 06:26 AM
fletcherscustoms fletcherscustoms is offline
thanks,
No clue I will ask my customer
Chad Fletcher
Fletcher's Customs and Speed
229-221-4690
[email protected]
Old 07-25-2011, 12:50 PM
Well we wrapped up the sheetmetal install this weekend. And are ready to move to the fun and boring stuff!! bodywork!! Before welding on the quarters the entire inner structure was blasted, epoxy primed, then lined with bedliner material. All for good piece of mind, and no fear of rust in the future. We replaced the floor areas that were rusted out, welded in a patch in the tunnel where it had been cut countless times over the years for different tranny installs. Got the quarters on the car, all the work in trunk done, replaced the inner and outer rockers on both side, as well as a couple of the inner qaurter wheel well pieces. I tell you Danchuk makes some damn good panels, everything fit like it was acutally made for a 57 bel air, lol. Only thing I don't like is its all bare metal, and down here in the south it all you have to do is touch or lean on it and it forms surface rust. Car will start the bodywork process tonight, with a full DA job to remove rust, full coating of epoxy primer, and then the fun begins. Anyways here are some pics
Chad Fletcher
229-221-4690
[email protected]
