Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 02-03-2011, 08:12 PM
Wybrow's Avatar
Wybrow Wybrow is offline
Here is mine
Old 02-04-2011, 06:40 AM
N2TRUX's Avatar
N2TRUX N2TRUX is offline
Its got a few pieces missing, but still looks like a good solid truck...er....start.
Old 02-18-2011, 09:31 PM
dropped72ss dropped72ss is offline
My truck[IMG][/IMG]
Old 04-01-2011, 07:11 PM
Dr G's Avatar
Dr G Dr G is offline
Default 1956 F100 Pro Touring Shop Truck
Hello,
This is my first post here. Not sure if my truck fits this thread. It's not a tow vehicle or parts hauler for a shop. But it is sort of a ProTouring Shop Truck for lack of a better description. If anyone has a better name for it I am all ears.
Although it is far from finished, here is the description so far:
Reinforced frame with truck arms and custom front IFS w/ cross-over bar
Fronts shocks = 20”QA1 6773
Rear shocks = Bilstein
Springs = 300lbs/in front, 200lbs/in rear
Brakes = Wilwood, 14” rotors up front w/ 6 piston SLR6 calipers, Wilwood under-hung pedal cluster with two Tilton master cylinders and balance bar
Engine = Ford Racing S347JR (350hp, 400ftlbs)
Transmission = reworked C4
Rear End = Ford 12” with Speedway Engineering lightweight housing and Truetrac limited slip
Front axles moved forward 4 inches with reworked fender openings
Rear fenders widened by 1.5 inches
Wheels = Wheelsmith Aluminum Smoothies. 17”x8” front (20.5lbs), and 17”x9.5” rear (21.5lbs)
Tires = Diamond Back Whitewalls = 255/60-17 front and 275/60-17 rear
Steering = Flaming River quick ratio power rack with KRC PS pump and remote reservoir
During the initial build I put a premium on keeping the truck as light as possible, with a wide torque curve. Making it easy to drive on the street and good for auto-x. Moving the front axles forward, and moving the engine back by massaging the firewall helped with weight distribution. The #1 cylinder is behind the front axle centerline.
I have additional things planned like aluminum bumpers and lightweight aluminum bucket seats. The interior will be aircraft inspired (WWII era).
I waffled for a long time about going with traditional looking wheels vs. more modern wheels with lower profile tires. For now I decided to keep the whitewall look while adding as much performance as possible.
More to come as things progress.
Gustave
Old 04-02-2011, 08:45 AM
PASD U PASD U is offline
Default the "Fly100"
I don't know what others may have or might call it, but I'm thinking it's One Fly Ass F100...no pun intended on the WWII aircraft theme.
I would love to do a vintage military-inspired truck myself.
Old 05-25-2011, 01:30 PM
dadto2jays's Avatar
dadto2jays dadto2jays is offline
I dont remember if I have posted mine in here but here are some picts of it to share. My goal was a semi stock looking truck with serious power under the hood...
Old 05-25-2011, 03:07 PM
56pickup's Avatar
56pickup 56pickup is offline
I love your truck! i love 56 f100's
can you please pm me some more details on your suspension setup?
Originally Posted by Dr G View Post
Hello,
Gustave
Tyler
Old 07-06-2011, 05:37 PM
Tricky's Avatar
Tricky Tricky is offline
Default Pro Trucks
This is what I go racing with.
Name:  Our pics 171 - Copy.jpg
Old 07-07-2011, 05:44 AM
Nice.
Old 07-09-2011, 04:16 PM
Tricky's Avatar
Default Pro Trouring Truck
Here's what I take around the track!
