Old 07-26-2011, 07:01 AM
ccracin's Avatar
ccracin ccracin is offline
Have you looked at mounting it horizontal in front of and at the base of the rad? You would have to run fans unless you put some type of dam or splitter on the car to direct air up through it. Thinking out of the box a bit.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 07-26-2011, 07:33 AM
wmhjr wmhjr is offline
I have but don't think there is enough room in front of the rad/core support to fit it. I would be very surprised if there were. The other issue would be that it would be right up against the bumper if that could even happen, so you'd risk catastrophic failure of the oiling system even if you just bumped the bumper. There really isn't any room other than n front of hte rad/core support due to the (low) height of the car.
Old 07-26-2011, 07:47 AM
ccracin's Avatar
Fine then, I say jack the engine up and build a new car around it!
Chad
Instagram - @cctek
Old 07-26-2011, 08:00 AM
Exactly. I'll start right on that. What kind of chassis can I get for $75?
Old 07-26-2011, 09:37 AM
Track Junky's Avatar
I'm using a System One remote oil filter system, Setrab 14"x6" oil cooler, Mocal oil thermostat, all done in 12 AN lines. The oil filter and cooler are mounted left and right of radiator.
I have some old pics that i will post. With temps reaching as high as 300 I would definitely pick up a larger cooler with fan and thermostat.
Gaetano Cosentino
Old 07-26-2011, 09:44 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Gaetano what type of oil temps are you seeing on 90* day 20 min sessions? Water temps?
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 07-26-2011, 09:48 AM
Last year on a 104* day I never saw water temps over 200*.Oil temps have never been over 220*
Gaetano Cosentino
Old 07-26-2011, 11:13 AM
The WidowMaker's Avatar
im running one in the radiator. its better than nothing, and i dont plan many track events over a few laps. i do have a chevelle and it runs a wider radiator and larger fans than the camaros. im hoping that the added volume negates the oil cooler being inside. prc has a bitchin setup and i hope it works as well as they say. todds running the same setup and i havent heard of any issues.
"The WidowMaker"
Old 07-26-2011, 11:03 PM
CarlC CarlC is offline
The Mocal thermostats will bypass some oil through the cooler below the set temperature. Mine is the higher 203*F version and I can't make the oil get that hot. On the street the temps never get over 180*, and that's on a really hot day + running the engine hard. I have a three-way ball valve that will go in soon so that the cooler can be isolated for non-track days. Cold oil is no bueno.
http:www.vaporworx.com
Old 07-27-2011, 05:14 AM
Carl, I hope to have the same issues. During normal driving, my oil temp is 180 even on hot days in traffic. It's at the track that's the issue. I have the Prc cooler on order now. Keeping my fingers crossed. I just need to deal with getting the oil to the cooler, as there is a challenge with that in my build.
