Old 08-10-2011, 01:27 PM
skatinjay27's Avatar
Originally Posted by elitecustombody View Post
2nd gen have completely different style/shape wheel openings compared to any generation mustang,so it would be a lot of unnecessary work ,when original metal can be easily widened
yeah i know how the shape of 2nd gen wheel openings are
i wasn't disagreeing with you, i was just showing him an example of of a car that used junk yard flares like he was thinking about.
AJ
Old 08-11-2011, 08:43 PM
70 gsconvt 70 gsconvt is offline
Thanks for the replies. I don't care for the blue mustang's look that much. I guess I'm looking to do subtle so that someone will really have to look twice to see that's it's not factory.
Is pounding/stretching the metal out that difficult? I have good mechanical skills, but really haven't tried much in the metal fabricating area. Maybe I'll go find an old fener or two and give it a try.
1978 Z28, 350/4-speed......for now
1970 Buick GS convertible, 11.86@112 mph
Old 08-12-2011, 09:37 AM
Went to the yard today to look around. I found a 2001 Caddilac Eldorado and it has the same wheel well shape. So I grabbed a fender for $20. We'll see how things go.
Old 08-12-2011, 11:15 AM
elitecustombody's Avatar
why are you wasting time and money on something that will require more work than simply cut existing fenders and just add a strip of metal?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 08-12-2011, 02:35 PM
Can you tell me where I'd cut them to push out the fender well lip out 1.5" without distorting either end where it mounts? Or would I slice it up the middle at the top of the fender well and pull it out and fill in the space with new metal?
Old 08-14-2011, 05:15 PM
Cut right where the flare starts coming out of the body,leaving the ends attached all the way at the bottom, you will also have to cut the wheelwell as well ,pull the fender out to your liking and weld a piece of metal shaped like crescent moon
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 08-14-2011, 08:08 PM
Sounds like a good idea. I just don't want the fender well lip to start going down towards the ground when I do this. But I guess if I'm just pulling it out about 1.5", it shouldn't drop much.
Thanks for the idea.
Old 01-16-2012, 03:20 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Default recommendations for cars to pull flares off of???
Bump to the top!!
I'm starting to look at flares for my next project. I like the idea of cutting flares off another car and grafting onto my project. The wheel openings have rot on the edges, so I need to rework the sheet metal on the openings anyways. And the rot means that I can't have someone beat out the existing sheet metal to the desired shape. I may be altering the wheel base too, so sheet metal surgery is going to be part of this activity no matter what.
Does anybody make sheet metal flares that can be worked and welded into existing sheet metal? Or there is always cutting them off another car.
Possible donor that have the look I'd like is the 2000's BMW M3/Z3.
This is the look I am shooting for, see the photos. 1.5 to 3 inch wider is what I'm looking for.
BTW, I don't like the look of the plastic/poly flares that are common on 4-Wheel Drives and SUV's, in particular the ones that look like a plastic bolt on, that really isn't the look I want. And I'd consider grafting fiberglass as long as it doesn't look too much like a hack job/bondo art project gone bad.
DETONATOR - 69 Camaro RS
