Old 09-14-2011, 12:22 PM
ParkerRS's Avatar
ParkerRS ParkerRS is offline
After getting the interior mocked-up and built ready to cover the car went back to the body shop.
After reading about James Shipka's One Lap Camaro and Steve Rupp's Bad penny which both use the same three link rear suspension, it was evident that a rear sway bar would be needed to tune it in. I'm not sure what rate bar will actually be neccesary, but fitting one before paint is easier. I sourced a bar from Helwig which was designed by David Pozzi for the OLC car. The clearance for the end links was the problem. We cut the rear floor pan and built two pockets which will both mount the end-links and provide clearance for the bar ends.
Hopefully this will give a good start, as the rear bar is adjustable. If it doesn't work out then helwig can make a different rate bar by this pattern, which would make it a simple swap out with no fab work to be done.
Friday the bottom of the car was painted.
The filling and smoothing of the firewall with one of the new weld-in DSE close outs was finished today and will be sprayed tomorrow.
Once that is done the car will get back on it's suspension for the final time. Painting of the top side will begin then as it has already been blocked 7 times while assembled and mocked-up.
It's starting to feel like Christmas. The ceramic and powder coating came back today. The tank and annodized parts will ship in next week. I used the previous tank when switching my grey 73 to fuel injection. This allowed me to order a new one for this project with the all new Vaporworx fuel system including the Pressureworx PWM controller.
Tommy
1973 Camaro - Fast burn 385, baer, hotchkis, hydraboost, 700r4, vintage wheelworks v-45s, finished 2007
1972 Camaro - Project Fool's Gold - LD 3-link, DSE sub-frame, LS2 stroked to 402, TKO 600, In progress
Old 09-14-2011, 04:20 PM
ma73z's Avatar
ma73z ma73z is offline
Almost forgot about this one, good to see it going again Please keep us updated with lots of pics
Old 09-14-2011, 04:24 PM
70rs's Avatar
70rs 70rs is offline
Yeah, what he said. ^^^^
Eric
Old 09-14-2011, 04:48 PM
Freakin awesome Tommy! Glad the car is still being built even if it was moving slowly. Thanks for bringing us up to speed.
Old 09-14-2011, 04:49 PM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Tommy,
There is something to be said about builds taking longer to compete. Vaporworks, plain and simple works!!! Adding the rear sway-bar.. Thumbs-up !! I love the undercarriage colors.
Hope you can make RTTH this year just to hang out!! I'll be there socializing, without the hobby in tow.
Matt
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 09-14-2011, 04:51 PM
protour73 protour73 is offline
OMG!!!!! Say it isn't so, update pics from Tommy???? (Insert --> sound of a body hitting the floor from fainting)
Thankfully I keep up with your car's progress behind the scenes!!
Old 09-15-2011, 06:12 AM
ParkerRS's Avatar
Thanks for the comments guys. I'm heading out to the body shop Friday. The firewall was finished yesterday and will be getting sprayed today.
The exhaust is back from being ceramic coated along with the sub-frame and rear housing which had to be re-powdercoated. After welding the down bars to the front along with tie down brackets the front needed to be re-done. The rear housing was also modified for the sway bar so it also needed re-coating.
I'll have some fresh update pics by the weekend. This will be something new compared with the last year, fast progress!
P.S. You can get up off of the floor now Scottie!! LOL
Tommy
Old 09-15-2011, 07:55 PM
dropit69 dropit69 is offline
Hot damn Tommy...looking good....its about damn time..lol..
Darrin
1971 Camaro
1971 Camaro RS
1973 Camaro RS "Dreamsicle"
1969 Camaro Coupe
1969 Camaro Convert -Pro-Tour build
www.fquick.com/dropit69
Old 09-15-2011, 08:15 PM
Very Nice !
Old 09-15-2011, 09:01 PM
Andrew Andrew is offline
Great looking work you're doing. Even better project name!
