Old 10-10-2011, 06:30 AM
ccracin's Avatar
ccracin ccracin is offline
Originally Posted by jharris View Post
Hey Guys,
Here are another few thoughts.
We were originally part of Littelfuse. I spent about 17 years there and led the development of ISIS. In early 2009, I led a team of investors to break of business off to manage it independently. Littelfuse it still a critical part of our business. They are part of our supply chain and we work together on specific market opportunities.
ISIS was originally developed for the off-highway, agriculture and military markets. We stumbled into the restoration, racing and performance markets literally by accident. The exact same hardware that has been powering the One Lap Camaro since day one, is used in busses, RV's, limousines, military trucks and command vehicles. Here's a good example.
This is one of our customers that builds high-end recreational vehicles. Their typical install has 1 MASTERCELL and 6 POWERCELLS. Check out the video at about the 1:15 point. You will see the front part of their install in the coach.
https://www.youtube.com/watch?v=AvU1v...geDecA&index=5
Littelfuse is the industry leader in automotive circuit protection. As such, our cells are filled with components to protect the system and the users from short circuits, resistive overloads, electrostatic discharges, load dumps, EMI and other nasty things that can happen in the automotive environment. The system was tested and qualified to General Motors' 3172 underhood specification. This battery of tests covers includes things like mechanical shock, vibration, thermal shocks, heat soaks, cold soaks, chemical exposure, salt-spray and salt-fog, immersion testing and electrical overstress.
That being said, we have had failures in field. Both James and John have examples of this. In both of their cars, they had issues because of the circuit protection components that exist in the system. In John's case, there is a fuse on the MASTERCELL that protects the power feed in the CAN cable. In James' case, a diode that is intended to protect the processor from high-voltage did its job.
The system was originally designed of commercial applications, which have pretty specific convetions on how to wire vehicles. Since most of these applications are pretty regulated, the circuit protection schemes were tailored tightly.
We have learned a lot about how guys have been applying the system in our aftermarket applications over the past few years and we have adjusted the levels of circuit protection to the overall system in all of the systems that we are shipping now. For example, the simple change of a fuse rating on the MASTERCELL from 0.375 amps to 0.500 amps eliminates what John Parsons saw in his car.
I hope that this gives you more detail.
Jay
Jay,
Thanks very much for posting and showing this community the type of service you provide. I have a question with regard to your last points about improvements in circuit protection. I have a system that I got as part of the group buy. Would my units have this revised circuit protection? If not, can I get it. Thanks very much. Keep up the good work. We should be getting close to laying the system out shortly. I am sure I will be in contact for some help!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 10-10-2011, 04:02 PM
jharris jharris is offline
Default Fuses...
Hey Chad,
You have the diode changes but I think that you may have the smaller fuse on the CAN power feed.
Give us a call at (847) 232-1991 and we can arrange to send you the larger one.
Jay
Old 10-10-2011, 05:11 PM
ccracin's Avatar
Thanks Jay. I have some other things I want to discuss as well. Hope all is well. Talk to yah soon.
Chad
Instagram - @cctek
Old 10-13-2011, 10:01 PM
jeff71 jeff71 is offline
Check out Eastbaymusclecars.com they did a 70 Chevelle with the ISIS system.
Old 07-27-2012, 03:50 PM
Z10ROD's Avatar
Z10ROD Z10ROD is offline
my head is hurting ( i am in process of my first isis system install)
WWW.RODSCARCRAFT.COM
Old 07-27-2012, 06:15 PM
canrc canrc is offline
I just finished my install -- some of the best customer service and support in the industry! The hardest part is mounting the cells after that the system is awesome!
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 07-28-2012, 12:17 AM
FETorino's Avatar
FETorino FETorino is offline
I'm glad to hear I have an ISIS sitting in a box waiting to go in my project.
Rob in SoCal
Old 08-06-2012, 04:19 PM
Z10ROD's Avatar
doing better now or understanding a little more I should say just a different train of thought. I got the cells mounted and kinda mapped out and no haven't been working on since my last post more thinking than anything
key fob
push button start
LS3 /4L60E
Vintage air / electric fans ( trinary switch)
have done a bunch of AAW installs and know how to keep them clean
Old 08-09-2012, 02:48 PM
Z10ROD's Avatar
Old 08-09-2012, 02:54 PM
I wish someone would explain to me what savings in labor etc the ISIS system saves?
Your's looks great so far!
