Old 10-19-2011, 11:42 AM
Track Junky's Avatar
Keep in mind that the trailor tires will get hot during transit so they probably exceeded the 80 lbs if you put 80 lbs into them to start with.
Great job on the track btw!!
Gaetano Cosentino
Old 10-19-2011, 12:50 PM
Lateral-g Moderator
80 psi. Holy crap batman. That must have a had a eventful blowout. Did it damage the trailer fender?
Old 10-19-2011, 04:12 PM
80#'s is the COLD max tire pressure rating....
Thanks for the kudos -- I sure had fun!
Old 10-19-2011, 04:18 PM
Ummmmmm..... it got my attention.... like a cannon going off! And I'm an internationally licensed pyro --- so I've heard my fair share of explosions!
This thread is worthless without pictures......
Old 10-19-2011, 04:23 PM
Just for clarity of the situation --- those tires have MANY MANY long distance trips -- as in Scottsdale and back to Seattle several times -- LA and back several times - So it isn't the air pressure that "suddenly" blew the tread off TWO tires on the same trip.... my guess it DELAMINATING.... since both tires suffered the exact "tread loss"....Neither tire blew out the sidewall....
Just FYI -- Load range "E" tires are 80# cold max pressure --- you can have the same size tire with a lower load range rating and it will have a lower max pressure.
Old 10-19-2011, 06:21 PM
Lateral-g Moderator
You are a scream. Glad your safe.
Old 10-19-2011, 06:59 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
lets move this out of the for sale section.
maybe race car section
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 10-20-2011, 05:12 AM
ccracin's Avatar
ccracin ccracin is offline
X2
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 10-20-2011, 07:16 AM
camcojb camcojb is online now
been thinking about it for a while. Moved, and re-titled.
Old 10-20-2011, 07:29 AM
Yep - Thanks Jody. As usual in any thread I post in - it gets jacked...
All the threads - to me - are just like a bunch of guys hanging out in "the shed" - the conversations wind around just like a race track... I've shown that staying on track is difficult for me! HA!
Last edited by GregWeld; 10-20-2011 at 07:33 AM. Reason: "on track" -- not "of track" -- dang fingers!
