Old 10-25-2011, 03:28 PM
DOOM's Avatar
DOOM DOOM is offline
Default Okay tire experts what gives here???
Marty (SYBORGTT) stoped by my shop yesterday to say hi and check out the progress of my car. He asked me what the size was of my Michelin Pilots I showed him that they were 345-30-19's he tells me his KDW 335-30-18's are wider than my 345's NO WAY.. So he took one of my tire home and sent me these pictures . WHAT???. You would think thats my tire on the left its not. I'm confused here, I had Mike do a deep tub for me so I could run a wider tire and the ride hieght I want. My tire looks tinny next to this 335. Anyone have an explanation. Heck if you look at the second picture thats his 285 and its not much small than my 345
Mario
USCOLLISION
Old 10-25-2011, 03:34 PM
CFster CFster is offline
Look at the actual flat part of the tread. Its close to the same width. That's what's measured. Michelin might tell you their tires generate less heat in the sidewalls.
'67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
'67 GTO LS3 Swap
Old 10-25-2011, 03:51 PM
tooblue's Avatar
tooblue tooblue is offline
Are his tires mounted on a wheel and aired up?
1995 Caprice,, LQ4 = 6.0 , L92, 4l65e, Phoenix AZ..
http://www.cardomain.com/ride/456803...caprice/page-1
Old 10-25-2011, 04:02 PM
SLO_Z28 SLO_Z28 is offline
Different manufactures have different sizes for the same tire size. 265/40/17 hoosier A6's are wider than 275/40/17 Nitto NT05's that are as wide as 295/40/17 HTRZ2's. Ran into this all the time selling tires, no 2 brands are exactly alike.
James F.
1974 Camaro Z28
Old 10-25-2011, 04:07 PM
DOOM's Avatar
No unmounted
Mario
USCOLLISION
Old 10-25-2011, 04:10 PM
DOOM's Avatar
James I understand what your saying but to me this is a bite rediculous! Almost unexceptable..
Mario
USCOLLISION
Old 10-25-2011, 04:16 PM
Mayhem Mayhem is offline
Some tire manufacturers measure the treadwith at the actual treadwidth and others measure at the sidewall even though they sell them as the same size tire.
I got a set of cheap 255 50 17 for my Impala SS to replace the BF Goodrich tires (measured at treadwidth) the cheapies were measured from sidewall and looked god awful, and tiny. Learned that lesson. I always check now.
Old 10-25-2011, 04:23 PM
I've run both on my car, they both fit fine on a 12" rim. Mounting will suck in that bfg.
Old 10-26-2011, 05:53 AM
Payton King's Avatar
Default I have 335/30/19 NT05's
mounted on a 12.5 rim and I am about 14.00 at the sidewall bulge each side.
That is suprising though
Old 10-26-2011, 07:15 AM
James OLC's Avatar
I'm trying new tires on the '67 and close to the same thing.
Old - 325/30-19 have a 13.0" section width with 11.6" tread
New - 305/30-19 have a 12.3" section width with 12.1" tread
Different tires from different manufacturers have different shapes (i.e. shoulders, sidewalls, etc.) and can measure up differently. Also - section width sizes are based on mounted tires on the manufacturers specified rim size - it's really hard to see whats what with them unmounted. For what it's worth on the same width rim your tire should be a quarter inch wider at the sidewall with a half inch more tread.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
