Old 10-31-2011, 08:33 AM
chevguy's Avatar
chevguy chevguy is offline
Nope I declared the 'right amount' paid a small fee and walked on by.
Old 01-05-2012, 01:26 PM
chevguy's Avatar
Just thought I'd update the outcome of fitting the kore3 brake kit and the hydroboost. The braking is nothing short of brilliant now. I do understand how some might find it touchy as you can use a big toe on the pedal and pull the car up instantly,but it's one of those things you will get used to quickly. My old system was as firm as pudding so this is great. Two great products.
Old 01-05-2012, 03:05 PM
Apogee Apogee is offline
Saweeet! I'm glad you got everything sorted out as I'm sure it's always a bit sketchy hand carrying parts half way around the world hoping you have all of the correct parts. If you have any pics, we'd love to see how it all turned out.
Cheers,
Tobin
KORE3
www.kore3.com
Old 01-05-2012, 03:52 PM
chevguy's Avatar
Will post some pics shortly, do most of you guys running a hydroboost run a power steering cooler. Just wondering as the pump etc feel pretty warm now.
Old 01-06-2012, 12:46 PM
To answer your question, most don't, but it is a good idea IMO. Just like any other lubricant, the closer you can keep it to it's ideal operating temperature range the better for not only the fluid, but the components that are relying on it. Hydroboost doesn't add that much load to the power steering pump and system relatively speaking, but every little bit helps.
www.kore3.com
Old 01-07-2012, 05:32 PM
Hydratech®'s Avatar
Supporting Manufacturer
HydratechBraking.com
Thumbs up SUCCESS DOWN UNDER IN THE LAND OF OZ!!! I love it when a plan comes together
Hi Ken I'm tickled to hear that all has indeed turned out excellent for you. Thanks much for the follow up post, as most don't take the time. Got pics by any chance? As much as we all like to talk about it, you know how we all love pics!
If you are happy now, just wait until you get a few hundred kilometers on your installation. The brake response will firm up considerably as the pads bed into the rotors, and the brake assist unit loosens up / settles in. This will require a firmer overall pedal effort overall, though welcomed as the braking will modulate very nicely. Do please make sure not to overheat the brakes at the wheels between now and then (of course, right?)
Power steering systems will run at general engine compartment temps, so 160-180 degrees Fahrenheit are typical. Initial PS temps may also be elevated until initial aeration of the PS fluid clears out. If you have continued elevated PS system temps after a few drive cycles, or the system gets crabby after a hard pounding session, then the following discussion will help:
http://www.pro-touring.com/showthrea...boost-on-track
I took it for a drive yesterday. The braking is absolutely brilliant now. It seriously is better than my brand new ute. Thanks for a great product,Ken.
Between Kore3 handling the brakes at the wheels, and Hydratech putting the squeeze to the package, it certainly better be better than the brakes on a stock ute!
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
