Old 11-10-2011, 11:49 AM
csangster csangster is offline
Originally Posted by Jtomas801 View Post
Thank you very much for the information and the nice words. I am going to have to research this a bit more. I believe that the Lateral Dynamics 3 link uses 5/8" bolts with 5/8" hole and 3/4" shank, so at least I know that set up is tested and works.
Thanks again,
Jon
Jon,
Sounds like you have it all under control. I apologize if I was spewing out too much information there.
I will watch your build with great admiration as it follows......I may use some of your ideas, if you don't mind.
Cheers,
Chris
Old 11-10-2011, 12:01 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
Originally Posted by csangster View Post
Jon,
Cheers,
Chris
No need to apologize, if I post something wrong or build some thing that might not be strong enough, I'd rather some one let me know now, before the car ever gets driven or some thing bad happens. So I really appreciate your advice.
And of coarse, you can use any of my ideas, because at some point I got them from some one else, lol.
Thanks,
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
Old 11-10-2011, 12:25 PM
coolwelder62's Avatar
Thank's Jon,Albert car turned out good,and worked well.My son Brandon is wanting a car so maybe will help him with something.I think I will put the Javelin on hold for now.Need to sell the orange camaro first.
Old 11-10-2011, 12:29 PM
Jtomas801's Avatar
Well yeah, you got to save up for the 9000 rpm supercharged, drysumped, ls engine for the Javelin first, lol. What ever the car is, it will be a awesome build.
Thanks,
Jon
Jonathan Feltis
Old 11-10-2011, 01:38 PM
Bryce Bryce is offline
Thanks again,
Jon
FYI
Example 4130
Tensile Strength, Ultimate 841 MPa 122000 psi
Tensile Strength, Yield 655 MPa 95000 psi
Old 11-28-2011, 10:19 PM
Jtomas801's Avatar
Well, I broke down. I am now an LS engine owner.
I just picked up this LS2 with less than 30k on it, came with a truck intake (not gonna use that), a LS7 cam with springs (stock ls2 cam is still in engine) and I believe ls7 injectors for $1500 off craigslist.
Seemed like a good deal, now I got to figure out what to do with it. Get a intake and throw my Dad's old 750 Demon on it or go efi. Hell maybe some ls3 heads.
But first, I got to get a T-56, an oil pan and a quicktime bellhousing. So I can position it in the car to make the engine and transmission mounts.
Now I have to sell all my AMC engine stuff, Who needs a all standard 390?
Thanks,
Jon
Jonathan Feltis
Old 11-29-2011, 01:01 PM
Now that's a great motor choice.
Old 11-29-2011, 01:33 PM
Jtomas801's Avatar
Thanks, I am hoping it works out good. At the moment I am think of just putting the ls2 carb intake on it with the msd controller, check the bottom end, arp rod bolts and maybe a small cam shaft, then just stick it in the car.
I want to do a stroker with good heads and a big camshaft, but I will be better off doing that as an upgrade later down the road after I get the car running and the suspension sorted out a bit.
Thanks,
Jon
Jonathan Feltis
Old 11-29-2011, 08:21 PM
asifnyc's Avatar
asifnyc asifnyc is offline
congrats Jon. that's going to be killer!
-asifnyc- penngrove, ca (SF bay area) asifnyc.com - Javelin Blog
1974 AMC Javelin NASA American Iron road race car
1974 AMC Matador road race project
1975 AMC Gremlin shell
1973 AMC Javelin/AMX - street
1975 AMC Gremlin - street
1970 AMC Javelin shell
1962 Rambler American vert
Old 11-30-2011, 12:02 PM
Jtomas801's Avatar
Thanks Asif, it is going to really lighten the front end up. What I like is, if some thing breaks, I could go to any parts house to get parts. Plus it doesn't hurt that my Dad works at a chevy dealer.
Hey Asif, do you want or know any body that needs an new internal balance aluminum flywheel for a six cylinder (works with '72 and up v8s)?
Thanks,
Jon
Jonathan Feltis
