Old 11-24-2011, 11:14 AM
HVAC111's Avatar
HVAC111 HVAC111 is offline
Default Oil Sending Unit
What Is The Best Way To Get At The Oil Pressure Sending Unit On A 1968 Camaro V-8, To Change It. Thanks
Old 11-24-2011, 11:43 AM
should be right behind and to the drivers side of the distributor. Usually removing the air cleaner is all that's necessary. Maybe disconnecting the distributor cap and moving the wires out of the way may make it even easier. I use a deep socket that fits the hex size of the sensor.
