GM stock bell housing for LS2/T56 magnum?
11-04-2011, 08:15 AM
samckitt
I was told I could use a late model GTO bell housing with LS7 clutch/flywheel. Anyone confirm this works? If so, what throw out bearing?
Thanks,
Scot
Scot
86 Monte SS
LS2/T56 Magnum
samckitt
Find all posts by samckitt
2
12-27-2011, 06:56 PM
HRD
bump for a reply. I also need to know this.
HRD
Visit HRD's homepage!
Find all posts by HRD
3
12-29-2011, 06:55 PM
GeoffP
I think the GTO and the F-body bell are the same depth flange to flange. Assuming this is true and the fact that the LS3/LS7 clutch works just fine in 98-02 F-bodies in theory it should work just fine.
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
GeoffP
Find all posts by GeoffP
Linear Mode
Switch to Threaded Mode
04:19 PM
