Old 01-20-2012, 09:38 AM
GrnDragon's Avatar
GrnDragon GrnDragon is offline
TR 6060 is the take out from the new Camaro (I'm sure you know this), but there is an issue with the shifter location and the output shaft that has to be changed to use in our "conventional" setups...
Here is a GREAT thread I found on ls1tech that describes changing everything over to make it a T56 Magnum.
http://ls1tech.com/forums/manual-tra...body-pics.html
[SIGPIC][/SIGPIC]
-95 TA Lime Green/Charcoal (Work In Progress)
http://www.cardomain.com/ride/214636...tiac-trans-am/
-69 Camaro Hardtop (Full Frame Project)
http://www.cardomain.com/ride/384710...vrolet-camaro/
Old 01-20-2012, 04:38 PM
454SSguy's Avatar
454SSguy 454SSguy is offline
I did know that they had the output shaft thing, and a driveshaft shop should be able to handle that no problem. That thread looks like what I needed to know. I know that guys bolt the T-56 magnums up to there BBC's. Now I just need to know how? What clutch / flywheel setups are used. What slave cylinders, and pedal assembly, and speedo and reverse light setup?
