Old 02-02-2012, 10:53 AM
ArisESQ ArisESQ is offline
Default 17 inch steel wheels and wheel covers/hub caps
Does anyone have a source for 17 inch steel wheels which would be similar to original equipment on 67' Camaro? Ideally in widths from 9.5 to 12 inches.
Also, is anybody aware of any companies that make wheel covers or hub caps for a 17 inch wheel, or if it's possible to make an oem wheel cover or hub cap fit?
Thanks guys.
Old 02-02-2012, 11:46 AM
fleetus macmullitz's Avatar
Thanks guys.
Post #1 in this thread mentions that style 17" wheel.
http://www.pro-touring.com/showthrea...LS7&highlight=
Old 02-02-2012, 04:51 PM
Thanks man!!
Old 02-02-2012, 06:35 PM
almcbri's Avatar
almcbri almcbri is offline
Check this out....
http://woodyshotrodz.com/Mark%20Clark/#35.JPG
Thanks guys.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 02-03-2012, 09:47 AM
JayR JayR is offline
Lateral-G Supporting Vendor
www.thewheelsmith.net makes all kinds of steel wheels and finding and attaching dog dish caps like the above post would be easier than what you want to do but given the difference in diameters, you may be able to slide that hubcap into the inner diameter as opposed to going over the entire wheel which would look cool and emphasize the width and diameter. You may be able to attach it by screwing sheetmetal tabs onto the wheel where the cap meets the wheel that grab it like a wheel would.
