Old 01-21-2012, 07:29 PM
intocarss's Avatar
Coming from a construction back ground I have used my framing hammer and my single jack many many times. And I dont leave to a track event without them.
As long as you don't use nails for cotter pins, We're good
Old 01-23-2012, 10:22 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Do you have a gasket? Does it fit the housing?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 01-24-2012, 12:08 AM
Thats what happens when Engineers start mixing with grease monkeys....have you seen the guys that work and build these for a living??? LOL I kid. Im an ex heavy duty flat rate mech, I can make fun of us.....however back to your issue.
Who installed the studs in the case? If they are crooked or misaligned you will have problems droping in. I always recheck the studs for square before I drop in the chunk. just sayin. p
Old 01-24-2012, 12:16 AM
oh just incase you need it...top secret stuff. burn after using please.
Old 02-16-2012, 04:51 PM
feeble feeble is offline
I am working on a 3D model of a stock early 70s 9" Ford truck housing. Any chance you could post a higher resolution shot of that so I can read the dimensions clearly?
Thx!
