Old 02-20-2012, 09:26 AM
Bryce Bryce is offline
Originally Posted by marolf101x View Post
The 48 Hour Camaro started out with 600# and 200#, which would be great for a daily driver that is occasionally autocrossed. We increased the rates for a big track event, and have kept it that way for now.
I wouldn't go any heavier on a similar street car!
If you put good information into the spring rate calculator TRUST THE RESULTS. We spent a lot of time making sure it worked correctly (how many other manufacturers provide this?) We use it all the time, and it's typically dead on, especially now that it lets the customer choose his/her use of the vehicle.
Your calculator is great. It is a dead on match to the one I created a few years ago when I was choosing spring rates.
To the OP,
Knowing your corner weights will make the calculator more accurate.
Old 02-20-2012, 09:57 AM
Payton King's Avatar
Default C5/c6
style front suspension with LS1 on 69 Camaro 550 lbs front
Jake's TA on rear with Sphon bushings 325 lbs rear (no sway bar)
For road course 700/500
Shocks need to be valved correctly to handle the higher rate.
Old 02-20-2012, 10:37 AM
Blake Foster's Avatar
Yea but your out of control !!!!
Blake Foster
www.speedtechperformance.com
Old 02-20-2012, 12:39 PM
Default You must not have seen me drive
Brian Finch rode/coached me on an auto cross run. Said I had the smooth thing down but needed to be more agressive. My simple brain took that and translated it too "you drive like a Pu$$y" LOL
Did you ever try a higher rate on the back of yours?
Old 02-20-2012, 02:05 PM
makoshark makoshark is offline
You do not have a high enough security clearance for such information
